Reusing the TPMS sensors and other related questions
Old May 30, 2004 | 05:19 PM
MrWigggles's Avatar
I am strongly considering getting the dark chrome factory wheels to be used as daily drivers and putting some super soft compound tires on my original stock wheels and reserve them for ocassional track use.
With that in mind here are my questions:
1. I want TPMS in my daily driver wheel thus I would like to keep my original sensors and move them over the dark chrome wheels. I think I read somewhere where Mazda suggests purchasing new TPMS for any new wheels that you buy and NOT reusing the old TPMS. That seems excessive to me and I would like to avoid that charge.
2. My old stock wheels which I will be using only for the track will need non-TPMS valve stems. This might be a really stupid question but are standard valve stems readilly available for the factory wheels?
3. New TPMS cost about $100+ a piece correct? If they are a lot cheaper than that, then I will just get two sets one for each set of wheels.
Not having TPMS in my daily driver wheels is not an option. I had so much trouble with previous car and low profile tires going flat with little notice that I won't make that mistake again.
Any info would be much appreciated. Thanks in advance,
-Mr. Wigggles
Old May 30, 2004 | 11:43 PM
rx8cited's Avatar
Re: Reusing the TPMS sensors and other related questions
Originally posted by MrWigggles
1. I want TPMS in my daily driver wheel thus I would like to keep my original sensors and move them over the dark chrome wheels. .......
I don't see why if the sensors and nuts are removed carefully, that you would not be able to reuse them on your new wheels. I'd suggest replacing the rubber grommets with new ones vs reusing and risking a leak.
2. ...... This might be a really stupid question but are standard valve stems readilly available for the factory wheels?
I'm not sure, but I'd hope standard valve stems fit on the factory wheels.
I can get you the valve stem hole dimensions off a stock 18" RX-8 wheel if that helps.
$89.04 for sensor/nut set on www.trussvillemazda.com RX-8 parts web site. They also list the wheels you want for $357.50.
Hope that helps .
I'm guessing you already saw the "Tire Pressure Monitoring System Service Tips" service bulletin from the other thread you posted in.
Pelleilee
Sep 29, 2019 10:07 AM
Warrior777
Jun 24, 2019 04:47 PM
michaelsk8er
Nov 9, 2015 07:06 AM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
tgaffner
Aug 20, 2015 10:55 AM
