Ticking sound
Old May 26, 2004 | 10:46 PM
RX-GR8's Avatar
Ticking sound
i just got back from a ride and when i parked my 8 in the garage i noticed what sounds like a loud ticking sound coming from the engine compartment. i took the emgine cover off and can't see any apparent reason for it. this is not the ticking when turning sound some people have experienced as the car is not moving. no cel was thrown. i'm bringing it in tomorrow without an appointment to get it checked. i'll let everyone know what happens.
Old May 27, 2004 | 01:22 AM
Mr M's Avatar
Evolution of REvolution
Sounds like a heat shield contracting to me, lots of cars make clicking noises as they cool down. Normal. Or maybe you are hearing the electic throttle, that goes through a closed-position check procedure after you turn the ignition off. Did it sound like an electric motor? Bzzzzz --click----weeeee.........?
Old May 27, 2004 | 01:50 AM
wakeech's Avatar
mostly harmless
no i'm pretty sure that's all just the heat cycling stuff. happens on all sortsa cars when the motor's hot and cools down quickly enough.
Old May 27, 2004 | 09:30 AM
RX-GR8's Avatar
i should have said when i parked it the engine was still running. i didnt shut it off. it's a rythmic ticking. like a valve tap although it can't be that but it sounds like it.
Old May 27, 2004 | 09:45 AM
MyRxBad's Avatar
Fb's rock!
Did you get the all the recalls done on it?
Old May 27, 2004 | 09:50 AM
RX-GR8's Avatar
yes at least according to the dealer i did.
Old May 27, 2004 | 04:54 PM
RX-GR8's Avatar
and the answer is
a/c compressor rear mounting bolt loose.
Old May 30, 2004 | 03:34 AM
Mr M's Avatar
Glad you had that found. Now you can drive with peace of mind
Old May 30, 2004 | 10:38 PM
RX-GR8's Avatar
yea weird that it came loose though.
Old Jun 17, 2004 | 10:09 AM
RX-GR8's Avatar
UPDATE:
the ticking sound is back which leads me to believe the air compressor mounting bolt is loose again. anybody have the shop manual and know exactly where it is and if so how hard is it to get to? i'd tighten it myself if i can.
Old Jun 18, 2004 | 02:31 PM
Tat2dRacer's Avatar
Originally posted by RX-GR8
and the answer is
I had the ticking sound to. (It sounds like valves hitting on a piston engine). Come to think off It, I think I heard it sometime after the first time they tried to fix the A/C. On my second visit I mentioned this & I have not heard it since. I do not know what they did, since paper work which I have not received, was supposed to be sent to me in the mail.
Old Jun 18, 2004 | 09:03 PM
RX-8 friend's Avatar
The only ticking sound I've heard from Maurice's car is the fuel injectors. Sometimes they are noisy and sometimes quiet.
Old Jun 18, 2004 | 11:52 PM
RX-GR8's Avatar
well guess what? this new clicking sound wasnt the a/c compressor bolt lose but 1 of the spark plug wires was off the plug and arching causing the sound. ran fine but i thought the idle was a little rougher. the mechanic pushed the wire back on and said if it comes off again they'll replace it.
Old Jun 19, 2004 | 03:22 AM
Mr M's Avatar
That wire didn't "come" off, somebody pulled it off and didn't put it back on properly. Another case of a dealer trying to protect their back by blaming it on the product!
Glad you found the final root cause.
Old Aug 10, 2004 | 06:25 PM
khoney's Avatar
FX8TED on my RX-8
I hear the same sound, especially when I start my car in the morning. It sounds like valve tapping in a piston engine, and is proportional to RPM. Guess I'll go check my plugs.
Old Jul 11, 2007 | 11:39 AM
rglbegl's Avatar
Baned
Bump for my ticking sound.
Started a week ago. Mostly I hear it at start up. But it sounds like a valve tick.
I will check my wires and A/C tonight.
Anybody else have this one happen . .
What was the cure?
Old Jul 11, 2007 | 01:22 PM
laythor's Avatar
I zoom therefore I am.
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
Racingjunkie
Sep 29, 2015 05:05 PM
tommy26Germany
Sep 29, 2015 10:33 AM
