exhausts
Old May 25, 2004 | 11:18 PM
crosswound's Avatar
exhausts
anyone know which exhaust gives the car my power at lower rpm's most of the exhaust only give it power in the high sometimes middle.
Old May 25, 2004 | 11:28 PM
HiTMaNN's Avatar
RX-8s Official Cool Guy
i dont think many do this is a rotary so most power is coming from the high revs
Old May 25, 2004 | 11:39 PM
mysql101's Avatar
I know the renisis isn't a 2 stroke engine, but this thread had me thinking about the CVEC tuned pipe for 2 strokes. Because the back pressure is important in a 2 stroke, the pipe was fitted with a spring loaded wall that expanded as the rpms climbed. The result was a larger pipe during high rpms and smaller at lower, giving the engine both high and low end.
Old May 26, 2004 | 01:03 AM
rotarygod's Avatar
The problem with this is that backpressure is important in a well designed 2 stroke exhaust but is absolutely the worst thing for a 4 stroke exhaust.
Old May 26, 2004 | 04:35 AM
Japan8's Avatar
Int'l Man of Mystery
Are you sure? I only ask because Odula's exhaust system is long with lots of bends and supposedly is tuned to make more mid -range power. Leg Motorsports' Sequential Muffler inadvertantly makes more torque at the point shortly before the actuator opens...
Old May 26, 2004 | 11:01 AM
rotarygod's Avatar
Those systems are tuning based on acoustic principles and not backpressure. A sequential system also isn't outflowing it's needs at that lower rpm before the valves open. It isn't backpressure that we want. It is not exceeding our flow requirements while still maintaining high velocity that is important.
Old May 26, 2004 | 11:25 AM
Japan8's Avatar
Oh, ok... I see now. Thanks RG.
O.T. I like the new addition to you sig. This one we both agree on...
Old May 26, 2004 | 11:37 AM
rotarygod's Avatar
Yeah I thought that one was pretty funny yet true. I rotate them out every once in a while.
Old May 27, 2004 | 01:48 AM
Gravity's Avatar
Hi god
I just send u a private message regarding some performance chip issue
Needed your advise , hard to get u due to time difference...hehe
Regards,
Gravity
Hunterkelley24
Jun 14, 2022 08:32 AM
arexatemate
Oct 28, 2019 08:16 AM
mdl0209
May 23, 2019 05:46 PM
Jb4ker96
Sep 27, 2015 10:06 PM
