RX-8's For Sale/Wanted RX-8 Private Party listings, no Dealer listings
{ FS } 2004, GT, 6MT $6,500: 171k miles on body
Old 08-02-2017, 09:07 AM
Is that a bike rack?
Lord ET's Avatar
TX *sold*
Year: 2004
Make: Mazda
Model: RX-8
Price: $6000
Mileage: 171000
Color: Red
Location (US State/Canada/Int): TX
The time has finally come. Selling my 2004 RX8 so I can get something that does baby-duty better. I am the second owner of the car and purchased it in 2008 with 42k miles on it. I have been a long-time RX8club member and should be able to be vouched for as a responsible owner. It's around 171k miles and is my daily driver. I had the engine replaced with a re-man by Town North Mazda in spring of 2011 @ 99k miles under the 100k mile warranty program. I have had no issues with the engine in the last 76k miles, I don't hesitate to drive it, and it has shown no signs of engine failure.
Full disclosure portion: 2nd/3rd (and maybe 5th?) synchros replaced when I first bought it because of grinding [I have the paperwork for it in the car]. I have been using Redline MT-90 ever since and the transmission does not seem to play well with other oils, not even OEM. 4th gear lightly grinds if you shift fast. If you shift like you actually understand how transmissions work, no problems.
+I have the Title in-hand, free and clear+
I have done 99% of the work on this vehicle myself, aside from any warranty work covered by the dealership.
Carfax
https://www.carfax.com/api/consumers...3eff13deab49d2
Warranty work performed
-All ECU flashes performed since 2008
-Driver/Passenger airbags both replaced
Irregular Maintenance performed
-Fuel tank retainer rings replaced (This is now covered by a TSB, so that will show on the carfax as incomplete. I have done the replacement already, though.)
-Engine - to - fuel-pump fuel line replaced due to warped fuel pump nipple (now a warranty-addressable issue)
-Fuel pump replaced due to warped fuel supply nipple
-driver/passenger fuel float sensors replaced (due to inaccurate readings)
-Radiator replaced 2014 due to puncture
-A/C Condenser replaced 2014 due to puncture
-A/C high pressure line replaced due to leak
-A/C compressor replaced due to seized clutch
-Belts replaced 2015
-Replaced trunk weatherstripping after leak allowed car-wash water into trunk
-SSV replaced 2014 after seizing closed
-SSV control solenoid replaced 2014
Regular Maintenance Performed
-Oil/filter replaced every 5-7.5k miles dependent on oil used
-Coil packs (until BHR kit) replaced every 20-30k miles
-NKG Iridium spark plugs replaced every 10-15k miles
-Engine air filter replaced every 2yr or 30k miles
-In-cabin air filter replaced multiple times
Performance oriented modifications
-Racing Beat cat-back exhaust
-RP short shifter kit
-Voodoo shift ****
-SARX Coilovers (height adjustable - Tein springs with Bilstein shocks spec'd for the R3 model)
-18x8.5 Work CR Kai - Gunmetal
-Continental Extreme Contact DW 245/40/18 [Fronts] 15k miles
-Continental Extreme Contact DWS 06 245/40/18 [Rears] 500 miles
-Racing Brake stainless steel brake lines
-Rotorpros slotted & cross-drilled brake rotors
-Hawk HPS F/R brake pads
-Work RS Type aluminum lug nuts (Red)
-Racing Beat condenser screen
-Oil cooler screens
-GT spec rear lateral brace
-Exedy Stage 1 clutch w/T.O. bearing
-Stainless steel clutch line
-Hotchkis Front & Rear sway bars
-BHR Coilpacks (2016)
-MSD plug wires
Creature comfort/personal style
-Laminex headlight covers
-Iridescent OEM blue/yellow fog light housings
-Goodbox CAN bus monitoring tool (Uses stock display for customizable UI)
-Foot-well Lighting (Red) comes on with ignition
-Gromm Audio Bluetooth, hands-free, 3.5mm jack, USB integration (Retain steering wheel controls)
-Full 5k LED interior/exterior conversion (except vanity mirrors)
-Wing mirror splash puddle lights (red)
-Tinted side markers
-Black emblems on the trunk
-Driver-side center console mounted holster (should fit most semi-auto pistols or cell phones)
-Engine bay light (actuated by interior stock-matching pushbutton from MSP Protégé)
-Fog light rewire (Fog lights can be turned on any time the ignition is on)
-Fire extinguisher mounted on rear seat rubbish bin (C-rated extinguisher)
-OEM aluminum fender strakes painted black
-OEM Spare tire (No mounting kit)
Wear & Tear
-Front aero lip: Paint color underneath shows from small rock chips.
-Light scratch from what appears to be a coat zipper: rear passenger quarter panel
-Typical small chips on hood from road debris
-Rear bumper blemish: Bolt on garage door scratched a part of the bumper in the middle above the LP
-Roof near moon roof: medium depth paint rub from old bike rack
Two accidents both covered under insurance:
-Driver Front/Rear door replaced when a Jeep patriot changed lanes into me on the access road
-Front bumper, radiator, condenser, various plastic clips replaced after hitting tire
Full list of modifications/service/maintenance since at least 2011 when re-manned engine was installed by North Park Mazda in Plano. Records prior to this are mostly present.
Attached Thumbnails 2004, GT, 6MT ,500: 171k miles on body-20160921_182906.jpg   2004, GT, 6MT ,500: 171k miles on body-20160921_182915.jpg   2004, GT, 6MT ,500: 171k miles on body-20160921_182925.jpg   2004, GT, 6MT ,500: 171k miles on body-20160921_182951.jpg   2004, GT, 6MT ,500: 171k miles on body-20160921_183003.jpg
2004, GT, 6MT ,500: 171k miles on body-20160921_183007.jpg   2004, GT, 6MT ,500: 171k miles on body-20160921_183029.jpg   2004, GT, 6MT ,500: 171k miles on body-20160921_183037.jpg   2004, GT, 6MT ,500: 171k miles on body-20140720_094739.jpg   2004, GT, 6MT ,500: 171k miles on body-20141105_072235.jpg
2004, GT, 6MT ,500: 171k miles on body-20170807_180800.jpg   2004, GT, 6MT ,500: 171k miles on body-20170807_180808.jpg   2004, GT, 6MT ,500: 171k miles on body-20170807_180815.jpg   2004, GT, 6MT ,500: 171k miles on body-20170807_180827.jpg   2004, GT, 6MT ,500: 171k miles on body-20170807_180841.jpg
2004, GT, 6MT ,500: 171k miles on body-20170807_180854.jpg   2004, GT, 6MT ,500: 171k miles on body-20170807_180907.jpg   2004, GT, 6MT ,500: 171k miles on body-20170807_180914.jpg
Lord ET is offline
Old 08-09-2017, 01:57 PM
Lord ET's Avatar
BUmp, Price drop, added interior pics
Lord ET is offline
