im an idiot and need help to remove a bulb in the light housing
Old Apr 6, 2004 | 11:59 PM
whosyourbaba's Avatar
HELP NEEDED!!! need help to remove a bulb in the light housing
So, i was installing my stealth bulbs today for my turning signals. I installed the rear fine, and it was time for the front. I put the bulb in the socket and then put it back. BUT I FAILED TO REALIZE I DIDN"T PUSH IT IN HARD ENOUGH! the bulb fell in the light housing (not sure what it is called). And the bulb is stuck in the housing at this current moment. I can't get it out, i tried using chopsticks and a really long tresser (sp?). I just pushed it farther since its so hard to control things with the lack of room. ANY IDEAS IN HOW TO REMOVE THE BULB OUT OF THE HOUSING? I have a friend coming in 2 hours to give me a long stick with a magntic on it. Hopefully works. If not, any other ideas. Im truely an idiot!
Tip for all: Make sure you push down hard on ur bulbs to make sure they snap it all the way. Or u will be an idiot like me.
Old Apr 7, 2004 | 12:03 AM
try a piece of double sided sticky tape on a dowling or stick
Old Apr 7, 2004 | 12:05 AM
no luck...
Old Apr 7, 2004 | 03:07 AM
So, i tried for 3 freakin hours. I cant get the stupid thing out! I figured out that the turning lights cant go out of the high beam part. I have to figure some way to move the bulb back to the turning light section any ideas. Right now its near the high beam area. I GAVE UP FOR TODAY!
Old Apr 7, 2004 | 03:35 AM
Nubo's Avatar
Lubricious
Practice (see pic)!
(sorry for the joke). Autoparts stores sell grabber tools with retractable claws, even flexible ones. That might help. If worse comes to worst you can always remove the cover, but that is a bit of work and involves removing the bumper as well. If you had a picture it might give people a better idea of the situation.
Old Apr 7, 2004 | 02:16 PM
haha thanks a lot for your replies. I got it out finally. I used a vacuum and connected that to a small tube. But i left many scratches in the housing, and kinda dirty now. CRAP! O well, thanks a lot.
Ccrosskno21
Jan 9, 2016 05:43 AM
Banshee8
Sep 2, 2015 03:03 PM
CARBONRX-8
Aug 23, 2015 09:52 PM
MatthewRJ
Aug 5, 2015 09:24 AM
Stubbs
Jul 28, 2015 09:23 PM
