New TSB out concerning flooding
Old Mar 12, 2004 | 12:29 PM
Rotary Nut's Avatar
"...I'm a Dapper Dan man"
Arrow New TSB out concerning flooding
Check it out!
TSB for flooding
Old Mar 12, 2004 | 12:39 PM
Winning_BlueRX8's Avatar
Limecat's High Priest
awesome. so looks like they'll reflash without a CEL then. My plugs were replaced from a nasty flood caused at the body shop...I wonder if they'll reflash mine. Not to mention, it takes cranks twice as long now.
Old Mar 12, 2004 | 12:42 PM
msrecant's Avatar
Hubble has been saved!
I just read through the new TSB (01-011/04). Some initial comments:
1. Mazda now officially recognizes that short distance trips can result in a crank/no-start condition (ie flooding). Previous documentation (and email responses) only made an obscure reference to reducing engine life.
2. Mazda officially indicates that this is a warranty repair.
3. Mazda strongly implies that this situation is the result of having the RENESIS meet the US Tier 2 Emissions classification.
4. Mazda indicates that the customer (you and me) should only use the de-choke procedure listed on page 11 (pedal to the floor). There are several references throughout the procedure for the service technician to do arcane things to avoid damaging engine/exhaust components.
5. I could find no mention of this issue being more likely with the AT version of the RX-8.
6. I could find no mention of hotter plugs being part of the remedy.
7. The customer de-choke procedure is a prerequisite before towing to the dealership.
8. It is unclear if the specified PCM update reduces the possibility of flooding in the future or is simply needed for the following diagnostic steps.
In general, it sounds like this issue is here to stay and can happen to any vehicle at any time after shutdown without proper warm-up. I am not sure but they may be trying to say that this is a US emissions issue and not really a rotary problem (personal conjecture). I don't think any of this is a surprise. Perhaps a little disappointing. I personally would have preferred a fix.
Old Mar 12, 2004 | 12:46 PM
Lufa's Avatar
Squishy Like a Lufa?
for a second there I thought they had a solution... Good to know and very indepth step by step instructions none the less. I do find it interesting that they reccommend the L calibration for customers who have experienced flooding.
Old Mar 12, 2004 | 12:49 PM
BillK's Avatar
More importantly and contrary to what Mazda USA customer service told me, they also now indicate that flooding can occur due to a manual transmission stall - very, very not good:
Examples: starting a vehicle and moving it to wash it, engine stall due to mis-application of clutch then restart.
This also means that this is (IMHO) a major safety issue that should be investigated by NHTSA (imagine stalling and being unable to restart in a bad place, like in the middle of a major intersection... as I've said before this is the argument they've made for forcing recalls due to bad fuel gauge level sensors and such.)
Old Mar 12, 2004 | 12:55 PM
greese's Avatar
It doesn't mean that if you stall it at an intersection it is going to enter a flooded condition. This TSB is just telling us what we all aready knew. If you start your RX8, let it warm up and rev some before you shut it off.
An immediate stall from the clutch on a cold engine could cause it to happen. Not every stall. I have stalled mine several times. Even on a cold start in the garage and it didn't flood on me then.
This gets so overblown around here there should be a permanent ban on the topic.
greese
Old Mar 12, 2004 | 01:00 PM
BillK's Avatar
Don't misunderstand me, either; I certainly don't mean to say it could occur on every stall.
However, it takes a few minutes for the engine to warm up (at least five if you follow the recommendations in the Quick Start Guide) - more than enough time to pull out of a parking lot, get into traffic, and then blow a shift.
To me, the most important thing is that Mazda USA customer service told me that flooding would only occur if you shut the car off cold or stalled and then let the engine sit awhile.
Their example in the TSB text indicates that is not necessarily true...
Old Mar 12, 2004 | 01:01 PM
musclecarconvrt's Avatar
Anybody catch that part about adding 10-15 cc's of oil to the intake. Guess that solves that little mystery.
Old Mar 12, 2004 | 01:15 PM
NAVILESRX8's Avatar
FWD Hater
Oh great.....ammo for all the chicken littles...
Getting ready to hear every what-if scenario.....
Old Mar 12, 2004 | 01:16 PM
NAVILESRX8's Avatar
FWD Hater
double post.....stupid slow reacting computer...
Old Mar 12, 2004 | 01:17 PM
Billk is one step ahead of you. :D
No offense Billk, you keep the realists in check.
Old Mar 12, 2004 | 01:22 PM
RX8_GT's Avatar
IMHO a good start (Pun) for Mazda - they have acknowleged the issue - hopefully more to come (a fix). John
Old Mar 12, 2004 | 01:24 PM
greese's Avatar
By the time you get out of the parking lot you will have revved the engine past 3000 RPM. More than safe enough to no longer worry about flooding should you stall it.
Old Mar 12, 2004 | 01:26 PM
BillK's Avatar
I apologize in advance if it sounds like I'm trying to make a bigger issue out of it than it is, but frankly I know I'm most likely to stall when taking off after starting the car. I also work late hours and so it's occurred to me more than once "if I stalled now and the car flooded, how hosed would I be."
In the circumstances in which I drive, rather, and that's why I see it as an issue.
shebam's Avatar
Bebop driver
Note the DISCONNECT THE SECONDARY AIR INJECTION PUMP TO PROTECT THE CATALYTIC CONVERTER step. This seems a very good step to make sure, right now, that you can do blindfolded. When mine flooded last year neither the dealer nor I was aware of this step. A few hundred miles later, CEL appeared, and repair was: a new CAT.
Old Mar 12, 2004 | 01:34 PM
loco4rx8's Avatar
BSG 75
Does this mean we can get the L reflash by saying we've heard about the flooding issue and are worried about it, or only if we've had the engine flood?
It sounds like you can only get it after a "crank/no start" situation has been verified. If this is the case, my guess is the "L" reflash is necessary, not as a fix, but for diagnostics.
If there's anyone who knows of anything new in the "L" flash that would help prevent flooding, please speak up.
Old Mar 12, 2004 | 01:36 PM
greese's Avatar
Its harder to do than you think Bill. Just give it a few good revs, stay in first gear a little longer immediately after startup and relax. You'll enjoy the ride more. I think you are letting some of the horror stories get to you. It has happened to some people, it could happen to you, but it's not an epidemic.
Old Mar 12, 2004 | 01:39 PM
greese's Avatar
I think just about any issue for service has "Flash the ECU" as one of the steps. I got my oil pan changed out and they did it even though i am pretty sure i already had it.
Old Mar 12, 2004 | 01:41 PM
loco4rx8's Avatar
BSG 75
Hmmmm, I'll be having my oil pan changed after the part comes in. I'll have to check to see if they do the reflash.
92trbolzr
May 18, 2025 09:04 AM
DylanForbes
25
Oct 31, 2017 05:47 PM
fistofmeat
Oct 7, 2016 12:15 PM
Danield97
Oct 10, 2015 05:58 PM
iphil
Sep 21, 2015 10:49 PM
