DIY: Rusted oil cooler line fix
Old Jun 23, 2011 | 08:20 AM
blckz28's Avatar
I live in Iowa and even though I hardly drive the car in the winter I still had an oil cooler line rust out and start leaking. It was the front half of the line that went from the engine to the oil cooler on the drivers side. Since the quick disconnect was fused together I needed to replace the whole line. The dealer wanted about $650!!!!!!! So I decided to just cut out that bad, get some barbed brass fittings, pipe, couplers and some hose clamps and take care of it myself.
DIY: Rusted oil cooler line fix-20110622_59.jpg
DIY: Rusted oil cooler line fix-20110622_66.jpg
DIY: Rusted oil cooler line fix-20110622_67.jpg
DIY: Rusted oil cooler line fix-20110622_72.jpg
DIY: Rusted oil cooler line fix-20110622_77.jpg
This ended up being a little too long so I removed one of the 5" pipes and all was good. I ran this set up for a day and no leaks
Old Jun 23, 2011 | 08:57 AM
paimon.soror's Avatar
Attachment 173571
Attachment 173572
Attachment 173573
Attachment 173575
Attachment 173576
Did you use off the shelf copper pipes?? A lot of industrial test plants use copper pipes to accelerate the oxidation of oils, you probably dont want to be using that on engine oil...
Old Jun 23, 2011 | 09:28 AM
I'm glad I don't have to worry about rust in Texas.
Old Jun 23, 2011 | 03:38 PM
blckz28's Avatar
Brass
ouimetnick
25
Sep 14, 2023 01:44 PM
HMSS013
Aug 28, 2015 03:08 PM
RXeckless
Aug 16, 2015 12:51 PM
mesaboogie
Aug 7, 2015 10:48 AM
