NW RX-8 Forum Serving WA, OR, ID, AK
Looking for local RX8'r who can change my spark plugs and coils et al
Old Mar 6, 2011 | 01:06 PM
Ross's Avatar
I don't know jack
Question Looking for local RX8'r who can change my spark plugs and coils et al
Greetings from the northwest. I was wondering if anyone around here is interested in changing out my spark plugs, coil wires for me. I would do it myself but my hands can't do that kind of work anymore. I am willing to pay you for your time $$$ food, drink et al. I really don't want to take it to a dealer and if I do it myself I know it's going to be friggin painful.
This is a 2004 AT less then 60K miles on it. The car won't start for some reason because I rarely drive it. I knew the plugs were going bad and was told by the dealer that I need to replace the coils and wires too. I can smell flooding and already tried holding the pedal to the floor and crank for 10 seconds several times. I have never had a problem with flooding before so I am pretty sure it's time to replace.
If interested give me a call.
Larry 425-485-6801 I live in Brier which is near Lynnwood right on the King Sno border.
Old Mar 6, 2011 | 01:19 PM
If you were closer I would definitely help you out; too bad
Old Mar 6, 2011 | 01:49 PM
pdxhak's Avatar
Official Post Whore
Lots of 8 owners in WA that should be able to assist.
Old Mar 6, 2011 | 02:46 PM
RawrX8's Avatar
Grocery Getter
Im located in Everett. Just have to plan a day a good week ahead of time for me. I work pretty much 12hrs-7days a week.
Old Mar 7, 2011 | 06:50 AM
Ross's Avatar
I don't know jack
Coolio!!
I am in the same work mode sched. I will let you know when the parts arrive from Paul and see if we can sched a time. I will make it worth your time.
Cheers!!
Old Mar 9, 2011 | 03:05 AM
makristal's Avatar
Sunlight Silver Bias
Once Dondo get's back, I'm sure he'd be willing to help out also! And if I had a place to do it (garage is currently a storage shack) then I'd help you out, they're easy to check, just annoying to get to!!!
Old Mar 12, 2011 | 11:33 AM
VashCloud's Avatar
Tuner Alliance CEO
Ive never done it on a rx8 but ive done it pently of times on a rx7 AND HAVE YOUTUBE READILY AVAILABLE!!!! LOL
Old Mar 12, 2011 | 11:38 AM
Wish I could help Remember to pick up spark plug anti seize.
Old Mar 12, 2011 | 09:51 PM
ANIBALRX8's Avatar
if you guy do it on a sunday, I wood be willing to help I did mine on my last oil change at 60,000 miles. so I know how easy it is!!!
Old Mar 15, 2011 | 11:53 PM
AngryBumblebee's Avatar
The Bawss
I recently did mine too (BHR upgrade) and new plugs. Its pretty easy, Brad let me know when you do this and maybe we can go together and Ill help out.
Old Mar 16, 2011 | 12:10 AM
RawrX8's Avatar
Grocery Getter
No! Your big muscular shoulders will just get in the way! You may sit back and bicep curl jack stands.
Old Mar 16, 2011 | 08:09 AM
Ross's Avatar
I don't know jack
OK I decided to give it a try by myself. I got the sparks out and the air-filter and it doesn't look too bad of a job. Parts are supposed to arrive today. I did an oil change while I have the car up on jacks and that wasn't too bad once I got a oil filter socket. Looking forward to some zoom zoom zoom. I need to meet up with you NW RX8'rs one of these days.
Cheers!!
Old Mar 16, 2011 | 06:09 PM
Ross's Avatar
I don't know jack
Ok I changed everything and it went smooth but car still won't start. Basically the same problem before I replaced the coil wires and plugs. I tried holding the gas pedal down but not go. Any suggestions appreciated. Going to seach the forum
Old Mar 16, 2011 | 06:39 PM
Were the plugs wet when you removed them?.....it's likely flooded....and with an auto..the easy way won't work
You will need to inject some ATF..or windshield washer fluid into the vac ports on the lower intake to help get some compression....
Make sure you have spark and fuel though
Old Mar 17, 2011 | 07:52 AM
Ross's Avatar
I don't know jack
I was able to deflood by pulling out the fuse on the fuel pump and disc the cat pump and then did the 5 sec start wait routine several times putting the fuse back in and out till it would start. The first couple of times it tried to start but ran real rough and died, instead of trying to keep starting I pulled the fuel pump fuse out and did the 5 sec on off several times then put the fuse back in eventually I was able to keep it running long enough to burn out the excess fuel and build up.
Zoom Zoom Zoom Look forward to meeting up with other local RX8'rs in the near future.
Thanks again for all the help and support.
Old Mar 18, 2011 | 12:23 PM
dondo's Avatar
100% baller (finally!)
glad to see you got it sorted.
20b-3rotor
Sep 2, 2015 11:09 AM
Zank300
Aug 26, 2015 07:40 PM
dohon
Aug 1, 2015 01:46 PM
thedragonrotar
Jul 22, 2015 08:46 PM
Belalnabi
Jul 17, 2015 07:48 PM
