Crazy Hazard Light/Blinker Malfuntion
Old Feb 12, 2004 | 01:33 PM
javahut's Avatar
OK... it rained hard here in Austin for about the last 2-3 days solid. I left my 8 out of the garage both nights since it was dirty from the rain and I figured sitting in the rain would clean some of the muck from the rain and the wet roads off.
Anyway, I'm in the office at work and co-worker comes up to me and tells me my cars lights are flahing sitting out in the parking lot. I think "What the heck?". I went out, and sure enough, the hazard lights are blinking. I get in and press the hazard light button... no change... no matter how the hazard light button is set, they're on. So I turn the key on, and I hear a little buzzing noise for a second(from behind the dash maybe?) then the hazards quit blinking. Check the hazards and blinkers and everything works fine.
So, I think , it's been raining, something probably got a little damp and caused a temporary weird little electronic problem. Everything was OK on the drive home. I garaged it for the night, thinking it would help it dry out a little.
So I get up this morning and start the car, and the left blinker/hazard goes nutty, blinking a million miles an hour, very erratically. It only does it after the engine is started, not just turning on the key. And it's only the left side now, front and back. And the only way I can get it to stop is the remove the hazard light fuse from under the hood, which unfortunately causes the blinkers to quit working. Also, if I turn the blinker or hazards on, they all function properly. Once I turn them off, the left goes wacky crazy again.
So, I'm still thinking something got wet and is causing it, but I don't know what or where it is. Guess I'll take it in tomorrow and see what they can find. Anyone have any ideas or had this problem before?
Old Feb 12, 2004 | 01:59 PM
dude you are screwed!!!!
no i'm sorry just kidding! i am sorry for your pain but that is just so erratic it's funny! go get it checked out right away. you don't want to wait only to find out it was some kind of ground fault and it shorts blowing your whole electric system or the whole fuse box or something.
Old Feb 12, 2004 | 06:17 PM
WHealy's Avatar
Mr. Blue Man
I know turn signasls will blink quickly to warn you if a bulb is out. Don't know if our "8"'s have this feature, but doesn't sound like you have your turn signal on either. I'd take it in for sure, but I'd try to disconnect the battery for like 30 minutes to see if that clears it up.
Old Feb 12, 2004 | 06:59 PM
DisneyDestroyer's Avatar
Careful, I bite!
Check this real quick:
honk your horn.
Does it make a sound? If not, it's possible you fried the fuse, and your alarm was going off with no sound (like happened to me recently).
Old Feb 12, 2004 | 07:13 PM
Omicron's Avatar
Definitely a short somewhere, and definitely an issue for the dealership to deal with under warranty. First I've heard of something like this too. You might want to have your dealership check the seals on all your external lights - I have heard about some of them leaking and/or fogging up, and this might be a related problem.
Old Feb 12, 2004 | 07:14 PM
good one DD definately something to look for.
Old May 27, 2009 | 10:38 AM
malofquist's Avatar
same thing is happening to me!! what was the fix?? anyone else had hazards and the flashing circuit buzzing from under the dash?
Old Apr 10, 2015 | 02:00 PM
plejman's Avatar
An old post, but did anyone found a solution for this one? I've got similar problem, but all of the blinkers are blinking like crazy with annoying buzzing sound. The problem goes away when I switch blinkers on hazards on, but when the switch is off it comes back immediately. The problem happens only with the engine turned on
Happened to me after starting my car after winter and a few month of not using it.
Here is Youtube video I've uploaded showing the problem:
Old May 3, 2020 | 04:37 AM
Dawson Shaul's Avatar
hi dude, i got exactly the same issue with my rx8. my blinkers are flashing and theres a buzzing noise under the steering wheel. if i turn a blinker or hazards on the noise stops until the signal is cancelled. also if i press the boot release it stops for a couple of seconds. could really use any advice available. did anyone get to the bottom of this issue.
kind regards.
dawson.
Old May 13, 2021 | 09:35 AM
Shlup's Avatar
I had this issue. Hold the odometer button with the car off and turn the key to 2. It should say “test” where your milage is. Do this twice and it should fix it
Old Dec 18, 2021 | 03:59 PM
MANIACman's Avatar
I had a tire blow out and turned the hazard lights on for hours (******* AAA never showed up) anyway after this these damn lights come on by themselves and don't turn off by pressing the Hazard light switch on and off a few dozen times. I replaced the blinker circuit. I pulled out the damn radio/blinker switch and still random turn on and off. WTF?!?! Really really starting to annoy me. I'm close to pulling the car battery. Does ANYONE have a clue what the hell is going on? I mean... Its a switch to the blinker box. Right? Remove the switch and it ought to be off all the time. If the blinker board / relays are goofed up a new one ought to fix it?
theguy1991
Aug 1, 2018 02:23 PM
Kozy
Apr 18, 2013 12:25 PM
Youwonder
Jun 7, 2011 10:01 PM
dlum125
17
Jan 11, 2011 07:17 PM
KuzuRyuuSen
Nov 7, 2005 05:47 PM
