Cabin heat
Old Feb 12, 2004 | 05:53 AM
skc's Avatar
skc
rev it up
Cabin heat
I live in Brisbane where we are experienceing some seasonal warm weather. i am finding that a fair bit of heat seems to radiate from around the centre console area where the gears are located.
i guess as the engine is located towards the end of the engine bay there is very little room between the front passangers and the engine and transmission.
I was wondering if anyone else has noticed this and if therewas any way to further insulate the vehicle
skc
Old Feb 12, 2004 | 06:02 AM
Hymee's Avatar
Race Steward
Yep - They get hot anywhere near the exhaust. My boot is noticeably cooler since I put the cat-back on.
Cheers,
Hymee.
Old Feb 12, 2004 | 06:36 AM
deano's Avatar
Re: Cabin heat
I've noticed this also, it gets quite warm.
skc
Old Feb 12, 2004 | 08:41 PM
pepe's Avatar
indicator-sensei
Yeah, have a look at a cutaway of the car, the back of the engine is basically next to your feet, given the space constraints, there's only so much they can do to insulate that area, hence tons of heat.
Old Feb 12, 2004 | 09:16 PM
skc's Avatar
skc
rev it up
hey Pepe, do you get people calling your black 8 a Batmobile as well? I reckon the black looks pretty cool. It certainly gets lots of looks.
SKC
Old Feb 13, 2004 | 03:03 AM
druck's Avatar
UK Owners Club
That lump in the floor just infront of the seat on a RHD is the catalyst, which is going to get a little bit warm.
Cheers
---Dave
Old Feb 14, 2004 | 01:00 AM
NickG's Avatar
Yup i reckon youy could boil a cup of coffee in the front drink holders after a vigorous drive! Not much use for cans of Coke in summer!
Old Feb 14, 2004 | 02:42 AM
timbo's Avatar
rock-->o<--hard place
Actually, cabin heat and, indeed, heat in the central compartments is OK if you are driving hard, but fast, as the air takes a lot of it away. It seems to get hottest in slower city driving
Old Feb 14, 2004 | 05:33 AM
msydd's Avatar
I find that with continuous driving it stays reasonably cool... but stop for an hour and then get in and drive and it is really warm.
Old Feb 15, 2004 | 02:47 PM
Choppy's Avatar
www.rx8club.com.au
it does get hot around your leg area.. My girlfriend complaining about it yesterday. So i put on the air con to shut her up hehe.
I always put my wallet and mobile in the center console were the cup holders are and they are both boiling just by a short 5 min drive.
Regards
Phillip
Old Feb 15, 2004 | 10:03 PM
RXP33D's Avatar
Hey fellow owners,
Ive just pruchased my 8 a month ago and ever since, the car continuously heats up in the cup holder compartment aswell as from the floor on drivers side. But never-the-less, this cars the bomb!
cheers Tuan.
Old Feb 16, 2004 | 05:32 AM
RXE16T's Avatar
'RX-EIGHT'
Yeah it gets pretty f##king hot inside the cabin.
The really annoying thing is the aircon vents don't seem to distribute the air flow evenly.
The centre vents have to be the worst design I've seen in a car for a while (both in aesthetics and function).
Old Feb 16, 2004 | 05:38 AM
Gomez's Avatar
Shifty Bastard.
Hymee....Seems like there's a market for the HymeeHeatShield
Regards Gomez
Old Feb 16, 2004 | 05:41 AM
Hymee's Avatar
Race Steward
The idea has crossed my mind
Old Feb 16, 2004 | 08:55 PM
Gomez's Avatar
Shifty Bastard.
Found this:
Originally posted by markpmm
FYI
I did a search on this and it has been mentioned in the past but not in this section..
FRONT CUP HOLDER / CENTER CONSOLE BECOMES HOT
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 00000000 40113124
Some customers may complain of the front cupholder area of the center console becoming hot after extended driving, causing cold drinks to warm. Due to the heat from the exhaust system (catalyst), the center console (cup holder area) becomes hot. This is due to insufficient insulation between the floor panel N cup holder. A insulation pad is available to reduce the heat transfer to the center console. 1. Remove the upper panel, hole cover (cigar lighter) and storage box from the vehicle. (See WSM 9-17-8) 2. Remove the six screws from the upper panel and remove the rear onsole. (See WSM 9-17-8,9) 3. Attach the heat insulater pad to the bottom of the front cup holder in the rear console removed at the above step NOTE: Be sure to attach the heat insulator pad so that the bottom of the cup holder is wrapped. 4. Re-install the parts reverse order of removal. Parts information: F151-55-161 Heat insulator pad
Regards Gomez
cliffkemp
Dec 24, 2024 10:48 AM
nadodave
Aug 28, 2019 05:55 AM
XianUnix
Sep 29, 2015 03:48 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Vedivan1
Sep 20, 2015 04:39 PM
