Air Filter Rmoval
Old Feb 11, 2004 | 10:32 AM
Mark Opperman's Avatar
Air Filter Rmoval
I purchased a K&N filter for my RX-8 but I can't get the original one out. Is there a secret to removing the filter? I've been at this for 2 days.
Old Feb 11, 2004 | 10:50 AM
Speed Racer's Avatar
Certified track junky!!!
I haven't found a way to check the air filter without removing the whole airbox. Don't worry, it sounds like it is a pain in the butt but it is actually very easy to do.
K&N had a nice set of instructions posted for their Typhoon intake.
Just do steps 1, 2, 3, 8, 9, 10 and then do the reverse to put it back together.
Old Feb 11, 2004 | 11:05 AM
I can't remove the box. The rubber flex between the filter and the engine gets in the way. I tried removing the box per the K&N instructions for the typhon, but it gets held up by the rubber flex.
Old Feb 11, 2004 | 11:10 AM
Jeff_pap31s's Avatar
YOU CAN DO IYT!!
Old Feb 11, 2004 | 11:42 AM
mazdaexe's Avatar
I had a hard time trying to take out the box too, but once u know how to, its quite easy. I actually followed some instructions from rotary extremes intake installation.
Remove the air hose connecting the filter and disconnect some of the wires. Then lift the air box up. That way, the bottom two plastic sockets will come out, then u can pull the entire box out.
Hope this helps....
I had the filter installed, I like it. The car feels very smooth throughout the entire RPM
Old Feb 11, 2004 | 12:12 PM
Loosen the hose clamp and push the flexible rubber hose away from the airbox. Then pull up on the rear of the airbox...
You are very close to getting the airbox out so don't give up now. After you do it once you'll find that it is actually very easy to do.
Old Feb 11, 2004 | 12:50 PM
rotarymagic's Avatar
Hope this helps....
Could you actually notice a difference from stock? If so, how much of a difference?
I have always liked K&N, but i have heard that oil from the filter can get in the intake and disrupt the o2 sensor.
Old Feb 11, 2004 | 01:31 PM
mazdaexe's Avatar
yes, i heard about the oil issue too, but many of my friends have the K&N drop in and I havent heard any problems from them. I think people that has oil problem with the filter are the ones that cleaned the filter themselves and put too much oil.
I wouldnt say that its faster, but defn smoother. With my exhaust and filter, I would say there is almost no hesitation to bring the RPM to redline..
Its pretty much a feeling, after driving the car with the drop in, I had a smile on my face.
Old Feb 11, 2004 | 04:49 PM
So are you going to have a professional clean and reoil, or are you going to buy a new filter?
Old Feb 11, 2004 | 05:13 PM
mazdaexe's Avatar
my friend just told me to get a new one once a while, so its come factory pre-oiled.
Old Feb 11, 2004 | 05:20 PM
mazdaman's Avatar
i changed my air filter, and i got my old one out just by forcing the air box open.
Old Feb 12, 2004 | 09:10 AM
Thanks for the responses. The cold temperatures here in Cleveland made it difficult to remove the air box from the rubber grommets. Once I warmed the engine, it removed with no problems.
Old Feb 12, 2004 | 09:54 AM
Congrats, on sticking with it until you got the job done. So what's next? How about a cat-back exhaust.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Jun 14, 2022 08:32 AM
Sato Tatsuya
Oct 5, 2015 03:09 PM
Danield97
Sep 30, 2015 05:59 PM
drlubell
Sep 26, 2015 11:58 PM
