DIY: The Ultimate Tune Up Compilation
Old Aug 30, 2010 | 09:12 PM
Gitfiddle's Avatar
Traumatizes Antelope
Ok guys, so the plan for this post is to make a one stop spot for looking up DIYs for common failures or Tune Ups for the Rx8 - in case anybody needs a good idea on what they should be doing to keep their car in tip top shape.
I'll start -
Engine and Fuel:
Oil Change
MAF Sensor Cleaning
Throttle Body Cleaning
Spark Plug Change
Fuel Sock Cleaning/Fuel Pump Removal
20 Brake Stomp (Resets eccentric shaft position sensor)
Motor Mount Replacement
Ignition Coils
Tranny and Diff Fluid
Exhaust:
Catalytic Converter Removal
Gutting the Cat
Wheels:
Front Wheel Stud Replacement *Hammer at your own risk*
Rear Wheel Stud Replacement
Changing Brake Pads
Electrical & Lighting:
Good list of Wiring
Bulb Code List
Headlight Bulb Replacement
Taillight Bulb Replacement
Misc:
Clutch Pedal Removal and Fix *You need access to a welder or a shop that can weld*
Old Aug 30, 2010 | 09:57 PM
rx8speed07's Avatar
Gimme that 8
this is a great idea. definitely hope this gets sticky'd
Old Sep 2, 2010 | 11:25 AM
slayer22's Avatar
sticky!
Old Sep 4, 2010 | 07:07 AM
legokcen's Avatar
The Turkish Delight
Cool! One of mine made it! I'm famous!!!!
Old Nov 20, 2010 | 12:14 AM
Dirt_Nasty's Avatar
Filth in a world of Clean
Ignition coils
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-mazda-ignition-coils-pics-178515/
Old Nov 20, 2010 | 12:54 PM
Cool thread, maybe also throw in a DIY for spark wires, diff fluid change, tranny fluid change (mt), removal of air intake box, how to change cabin filter, etc.
Old Apr 19, 2012 | 09:11 PM
Gitfiddle's Avatar
wow, i forgot about this thread and didnt notice it even made stiky. I Updated it for something Im gonna do this weekend.. and I'll go through and update it some more off the suggestions above.
Old May 16, 2012 | 09:18 AM
McGridDLe's Avatar
Delicious Sandwich
subscribed
Old Oct 27, 2012 | 01:55 PM
bandit12's Avatar
subscribed as well..
Old Feb 11, 2013 | 08:30 AM
ESBjiujitsu's Avatar
Own MS6 ... Want RX8 :)
awesome list!! Ill be performing all of the above once I pick up my 8! Should be ready to buy next month! Still finishing my ms6 part out
Old Feb 13, 2013 | 08:46 PM
saphryn135's Avatar
good basic list
Old Mar 11, 2013 | 11:05 PM
Gitfiddle's Avatar
Added a few more to the list. Some were already stickies but meh, i'm lazy
Old Mar 31, 2013 | 04:36 PM
coleFACTOR's Avatar
Want to say thanks to everyone who contributes to the DIY pages here. Picked up my 2004 last Sept., my first 8. Has 83.8K on it and was having engine running problems. I have a good feeling the previous owners did not do nearly enough maintenance. Did my ignition system and sea foam for the first time. Car is running like dream now. Better than when I first drove it. I'll be doing more next weekend. Props to everyone for the knowledge.
Old Aug 2, 2013 | 05:17 PM
toXiic's Avatar
what do u guys use for cleaning intake and throttle?
Old Aug 5, 2013 | 09:34 AM
Rogueain's Avatar
I just got a generic can of this throttle body, and air intake cleaner. Worked fine for me.
http://www.miataturbo.net/attachment...ine=1374425886
You can get it at Autozone. Make sure it's dry before reassembly.
I used napkins, and Q-tips to catch the grooves in the air tube. The Throttle body was filthy, and took me about an hour to clean, but it was shining bright when I was done.
The guys on here might know of a better method, or a better product. So, I would keep an eye on the thread, and see if anyone else responds. Happy cleaning!
Old Apr 21, 2014 | 02:04 AM
ktmrider9903's Avatar
hey guys, first i wanted to say thanks for this thread, its been pretty helpful so far!
ok, so im a marine stationed in socal, and im contemplating a road trip back home to Indianapolis, about 4100 mi altogether. ive done a few of the tune ups here, but i want to know if anyone could recommend any more that might serve someone going on a roadtrip well?
Old Aug 29, 2014 | 11:16 AM
ikanji's Avatar
AB
Just picked up a 2004 rx8... this is such a helpful thread! great job boys
Old Sep 4, 2015 | 02:22 PM
Hunterkelley24's Avatar
Engine rebuild
I know this topic pops up a million times so bear with me .i was gonna post my own thread but it wouldn't let me . So I'm gonna rebuild and port my renesis engine and I was wondering if I should just the whole engine rebuild kit (gaskets, o-rings, seals, springs, etc) or if I should just get the kit that comes with all new seals and stuff for the rotors . My engine runs fine and it actually still in the car right now I'm pulling it out this winter and porting it and when I rebuild it I need a little guidance . Sorry for the question since everyone asks it but I'm curious . And another thing is what is the solution to the "marbles in the can" noise or whatever it makes a weird noise around 6000-7000 rpms but goes away around 7500-8000 . Any reason why ?
tbiggybig
35
Jul 14, 2022 06:14 PM
Hunterkelley24
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Danield97
Sep 30, 2015 05:59 PM
