Help Please - Illuminated Start Button
Old Feb 7, 2004 | 10:48 PM
brat's Avatar
Had problems with my illuminated start button, and the fact that the instructions are in Japanese.
All connectors fitted with no problems, however encountered the following problems:
1. start button did not work
2. key was able to start the car even after wiring harness installed
3. No illumination
Any help would be most welcome.
I posted instructions at http://users.bigpond.net.au/rtjong/rx8.htm in PDF hope someone can help me translate the important sections.
Thanks in advance.
BTW the illumination worked as per pic.
Robert
Old Feb 7, 2004 | 11:06 PM
Doctorr's Avatar
Ricer is Nicer.....
Cool Wow...
That looks like a lot of work!
The symptoms (no start & no light) sound like the ground connection is bad (bottom of page 8 of the PDF). Check with a 'known good' ground point.
No other guesses, and sorry, no japanese.
doc
Old Feb 8, 2004 | 12:57 AM
M-ster's Avatar
Goodness! That looks like brain surgery for a simple start button. Maybe you can try PM takahashi since he's in Australia as well.
Old Feb 8, 2004 | 01:31 AM
brat's Avatar
M-ster,
do you have the start button installed? if so how does illumination work? is it on when you turn the key to ON and turns off when press the start button? or is it on all the time, can you also start the car with the key even though you can start with the button.
Robert
Old Feb 8, 2004 | 01:35 AM
brat's Avatar
Thanks doc, tried numerous ground points.
Old Feb 8, 2004 | 07:19 AM
takahashi's Avatar
I am not a DIY specialist but thx :p
I will try to look at the manual ... where in particular are you stuck?
Robert do you want me to translate the trouble shoot stuff... secondly just check all connection as per diagram... by turning the key to on and press both brake and accel - should the ON light illuminate
This thing sound look from the first time I look at it but I need the coin bag ;(
Old Feb 8, 2004 | 07:32 AM
takahashi's Avatar
Give me your fax no Robert... if you want me to translate any page I can fax across it to you tomorrow night
Taka
Old Feb 8, 2004 | 08:29 AM
M-ster's Avatar
Originally posted by brat
M-ster,
Robert
Sorry mate, I've not gotten my car yet, next week I'll be. Can't help you much here, that's why I've arrowed someone else, sorry takahashi:p
From what I know, the car can be started with either the key or the button itself. As for the rest of the question I can only answer you next week. But I hope you would have solve all your queries.
Cheers
Old Feb 8, 2004 | 03:00 PM
brat's Avatar
Hi Takahashi
Thanks alot for that, I will be most grateful. I just went by all the diagrams, no Japanese translation at all.
my fax number is (02) 9836 3162, and need all the help I can get at the moment.
I love the look of the button, looks good in the car I believe.
Thanks Again
Robert
Old Feb 9, 2004 | 04:06 AM
takahashi's Avatar
unable to fax tonight for some reason will try to fax tomorrow. is the fax number correct?
Old Feb 9, 2004 | 02:57 PM
brat's Avatar
yeap, sorry I picked up the phone, thanks for that.
Old Feb 9, 2004 | 04:11 PM
takahashi's Avatar
It is on the way now... Steve
Old Feb 9, 2004 | 05:00 PM
Need For Speed's Avatar
SPEED-8
im going to buy one to but i thinc its dificult to instal?
its very hard to instal if i dont now japanes!!!
i wheel need help to, wen you instalet i whel hasc you to help me.
pardon for mi inglish!
Old Feb 9, 2004 | 07:13 PM
XCENTRIC's Avatar
Oh, my eyes!! :D Not to be rude, but have you tried using spell check on word or similar software?
Old Feb 19, 2004 | 07:52 AM
M-ster's Avatar
Hi robert,
How's it going with your button? Hope you've got it fixed!
I've just got mine, so, key still can be used as normal (to start the car), the button will illuminate when the key is being turned to on position, and the lights will go off once the car starts up. Personally, my experience so far is that the car starts up easier with the key then the button. But, I still lurvesss the button.
cheers
Old Feb 20, 2004 | 01:52 AM
brat's Avatar
Hi M-ster
Congratulation on getting the car, the button works now and re-wired to work without the wiring harness. I love it personally, thats probably because I drove my friends s2000 (awesome car!). Many thanks to DMRH, as he got it working.
Old Feb 20, 2004 | 11:41 AM
jniamehr's Avatar
Young Rotor Head
Can you tell us where you got this part and how you installed it etc???
Old Feb 20, 2004 | 03:38 PM
rx8fanatic's Avatar
Here is the part from japanparts.com
click here
Go about half way down on the page.
Old Feb 24, 2004 | 08:53 PM
jniamehr's Avatar
Young Rotor Head
If you use this button, you still need to insert a key to drive the car, correct.... so what if any is the point of this... is it just asthetic?
Old Feb 24, 2004 | 09:24 PM
P Daddy's Avatar
Does this only work for RHD vehicles?
Old Feb 24, 2004 | 11:20 PM
brat's Avatar
P Daddy, The original kit did not work anyway on my car, so had to modify it to work. it replaces the coin holder compartment on RHD cars and to make it work on LHD needs modification.
see pics here http://users.bigpond.net.au/rtjong/rx8.htm
jniamehr, just for looks, feels good too starting with a button. (a mate has an s2000 and I loved the start button idea)
akagc
Aug 11, 2015 07:07 PM
MarkX
Jul 31, 2015 07:50 AM
Tyblat
9
Jul 29, 2015 07:20 PM
Stubbs
Jul 28, 2015 09:23 PM
Jmanie9515
Jul 20, 2015 07:29 PM
