Painting Interior Pieces
Old Jul 26, 2010 | 12:42 AM
vincephan's Avatar
My trim pieces look pretty bad from 5 years of wear and tear from the previous owner. I thinking about painting the pieces white.
To those of you who have already painted your interior trim, would a spray paint, DIY-job look good enough? Or should I shell out a bit more money to send it to a professional painter to get it sprayed correctly?
How much should both options cost? Any ideas?
Old Jun 24, 2011 | 11:29 AM
JPYRITZ's Avatar
Retired and bored
I have 05 BLK 8 and i took all the trim out of my car and painted it red looks great, i have had so many complaments. I used krylon plastic paint from wal-mart its was about 5-6 bucks a can. Just make sure you clean all the pieces well. I used alcohol pads, or you can use rubbing alcohol and a rag. it only took 2 coats. I'll try to post a few pics in a day or so. Hit me up if you need anything else.
Old Jun 25, 2011 | 05:39 AM
hoss -05's Avatar
Lucky #33
Do Not paint! Use vinyl and wrap. If it ever gets a scratch its much cheaper to fix and will look much better then most diy paint jobs.
If you do the wrapping yourself it will cost you less then 50$ for the whole roll and that would be enough to do every thing on the inside a four times over. If you dont like it peel it off and put on a different color.
https://www.rx8club.com/showthread.p...ght=vinyl+wrap
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
nferguson88
Oct 6, 2015 12:45 PM
SimonT182
Oct 2, 2015 10:33 AM
Quiggs321
Sep 30, 2015 05:34 PM
GK1707
Sep 27, 2015 07:33 PM
