Greddy Pulleys Need english instructions
Old Jun 4, 2010 | 06:27 PM
AndymanRx8's Avatar
Hey i just bought the greddy pulley kit for my rx8 but the instructions are all in chinese and japanise . i was looking for anyone that may have them in english and could send me a copy. Thanks
Old Jun 4, 2010 | 07:21 PM
KrumbZ's Avatar
1.3L of Fury
do you actually need instructions??
Old Jun 4, 2010 | 07:28 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Only reason I could think of is for the proper torque specs????????
OP, if the kit includes an alternator pulley, make sure you go get an impact wrench to aid in getting it off!
And, I don't know if these are under driven(and came with belts of not), so they could us different belts??????
Old Jun 4, 2010 | 07:56 PM
nuke0907's Avatar
Never Blend In
i have the Greddy pulleys. they do not come with a belt. use an impact wrench like already mentioned for the alternator bolt(21mm i believe). remove the screws on the water pump pulley10 or 12mm). you will need to loosen the alternator by turning the nut on the top of the bracket. you will need to loosen the one on front first. then the belt will come loose. remove your pulleys. install the new ones. the water pump one uses new screws. the alternator reuses the stock one. put the belt back on. tighten everything back up.
nuke0907's Avatar
Never Blend In
BTW, they are not under-driven, just lightened.
Old Jun 4, 2010 | 07:58 PM
nuke0907's Avatar
Never Blend In
here's a pic of mine how they came out.
Old Jun 4, 2010 | 08:02 PM
Mazurfer's Avatar
Noted for future reference!
You got the torque specs for him?
Wondering if the would be the same as stock in that regard?
Old Jun 4, 2010 | 08:04 PM
nuke0907's Avatar
Never Blend In
they are the same. i do not have the specs though. i just kinda tightened them til it felt right. lol.
Old Jun 4, 2010 | 08:14 PM
Mazurfer's Avatar
Yeah........most important thing is to check them after a few drive cycles to insure they are still tight.
Old Jun 4, 2010 | 08:47 PM
Mazurfer's Avatar
Yeah.............I suppose.
You're always bringing up those little things!
After the install................
Turn the car to on but do not start
Pump the brake pedal 20 times in a 8 second period
If you did it right the oil pressure gauge will sweep, if it doesn't....then start over again.
Old Jun 5, 2010 | 01:04 AM
AndymanRx8's Avatar
Thanks For the replys!
Old Jun 5, 2010 | 01:07 AM
laythor's Avatar
I zoom therefore I am.
if the pulleys are just lightened do you really need to reset the e-shaft?
Old Jun 5, 2010 | 01:25 AM
BG-8's Avatar
Shall we remind the OP about resetting the e-shaft sensor, too?
Isn't this done only if you replace the e-shaft pulley? As the e-shaft sensor is located by the e-shaft pulley and it reads the way it spins. I could be wrong... but if you only replace the alternator pulley and the water pump pulley, you didn't mess with the eccentric shaft sensor, so in my opinion it doesn't need to be reset. Unless you replace the main e-shaft pulley...
https://www.rx8club.com/series-i-trouble-shooting-95/real-way-clear-memory-169443/
Old Jun 5, 2010 | 08:02 AM
nuke0907's Avatar
Never Blend In
ANY time the e-shaft pulley is removed the sensor profile needs to be reset. So says the FSM.
From Nuke's photos it looks like the GReddy Pulley Kit includes an e-shaft pulley.
i never said anything about an e-shaft pulley. i did install an Agency Power one with my Greddy pulleys though when i did my turbo install.
Old Jun 5, 2010 | 09:05 AM
AndymanRx8's Avatar
I was wondering as well with the greddy pulley kit can you use the stock belts or do u need a difference size belt. If so whats the number on the belt
Old Jun 5, 2010 | 12:33 PM
faith&firepower's Avatar
My Other car's A Stryker
^ And the odd filter re-location kit.....that is also in Japanese....FML, but it shouldn't be too hard.
Old Jun 5, 2010 | 12:35 PM
nuke0907's Avatar
Never Blend In
same as stock.
Old Jun 7, 2010 | 11:36 AM
kersh4w's Avatar
Hit & Run Magnet
service manual in my signature.
Old Jun 8, 2010 | 10:41 AM
AndymanRx8's Avatar
Does anyone Know About the belt tension. Tourque specs ????
Old Jun 8, 2010 | 10:44 AM
bse50's Avatar
#50
There's a service manual for those things...
RXFEVER
Aug 29, 2018 10:14 AM
Hunterkelley24
Oct 1, 2015 09:11 AM
DeltaJ802
Sep 29, 2015 01:20 PM
