View Poll Results: If you've had milky/foamy oil with RX-8, what type of oil were you using?
Synthetic (more than 1 change)
1.92%
Synthetic (1 change only)
1.92%
Conventional (more than 1 change)
17
32.69%
Conventional (1 change only)
10
19.23%
Factory Fill
23
44.23%
Voters: 52. You may not vote on this poll
Got Milky Oil?
Old Jan 30, 2004 | 01:14 AM
Nubo's Avatar
Lubricious
Question Got Milky Oil?
Oh No! Not another Synth vs. Dino thread!
Interested to see if there is any correlation to the "milky oil" phenomenon and use of conventional vs. synthetic oil, or perhaps a mixing/compatibility issue.
Please vote if you have experienced this with your RX-8 (milky oil or foam on the dipstick, filler cap, etc)
If more than 1 applies, check the most recent.
Old Jan 30, 2004 | 06:21 AM
rx8cited's Avatar
No place to vote for Conventional (no change yet) in the poll? I have milky factory oil. I'm sure that geographic location (ambient temperature) is a factor too - DC Metro Area
for me.
rx8cited
PS: I did not vote ...... until factory fill was added to the ballot .
Old Jan 30, 2004 | 11:13 AM
Nubo's Avatar
Lubricious
"factory fill" is on the ballot
Old Jan 31, 2004 | 01:15 PM
Rx8Freehk's Avatar
Special Agent Member
More importantly.... is this normal? is it bad?
Old Feb 1, 2004 | 02:59 PM
LTAGFERN's Avatar
I'm wondering if "milky oil" is a phenomenon happening ONLY within the dipstick tube. Heating / cooling of the tube causing a mix of condensation and oil . . causing the cream colored 'globby' stuff.
Which is to say . . "milky oil" is NOT a problem anywhere else in the engine.
While checking my oil level this morning, I was very surprised at the amount of milky stuff over the length of the dipstick, and initially very concerned about a glob of the stuff on the bent end of the dipstick. After thinking about it, I decided the stuff on the end of the dipstick was possibly 'scraped off' the inside wall of the dipstick tube when I removed the dipstick.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
