Series II Technical and Trouble shooting Discuss technical details for the Series II RX-8 and any issues or problems you are facing
Clutch bracket?
Old Mar 15, 2010 | 10:35 AM
SheffieldSteel's Avatar
Intended acceleration
Clutch bracket?
I know it's a pretty shoddy piece of workmanship on the Series I cars, but does it need fixing on the Series II?
Apologies if this has been definitively answered already. I just wanted to hear from someone who's worked on a II and knows what to look for.
Old Mar 15, 2010 | 02:01 PM
xexok's Avatar
The part has changed in series 2, I know that. I read in another post that it changed from a B to a C at the end or start of the part number. Most of the clutch failures I read about have been at 40k+ miles. I dont think theres any series 2 with that amount of miles yet so its hard to say if it will last or not. I am most likely going to get mine welded just in case, it cant hurt.
Old Mar 21, 2010 | 04:49 PM
Kpoc's Avatar
2010 Sparkling Black Mica
I did mine after asking the same question about 2 weeks ago, and getting a they didn't change it answer.
Old Mar 23, 2010 | 10:32 AM
silverbullet05's Avatar
Installed the bracket on my 05' recently. It's very annoying to install, but after seeing how flimsy and weak the oem bracket was i'm glad i decided to have it on there!
If it's anything like the series I i highly recommend getting the bracket vs spot welding it.
Last edited by silverbullet05; Mar 23, 2010 at 10:33 AM. Reason: grammatical errors. lol
Old Mar 23, 2010 | 11:30 AM
Charles R. Hill's Avatar
Owner of BHR
Who is suggesting spot-welding as a fix?
Old Mar 24, 2010 | 01:55 PM
no one in this thread, but other threads i have seen people just weld the bracket and call it a day. i would not trust it even if it was welded correctly.
Old Mar 24, 2010 | 02:04 PM
Owner of BHR
"Trust" has nothing to do with it. The dozens of people whom have either purchased the welding service from BHR or followed my advice on the welding, itself, have never had any issues afterward (except when the welding was not done properly).
I really don't care if people use a bolt-on bracket, weld it themselves, or have a professional do it. In any event, some sort of reinforcement is strongly advised.
Old Mar 24, 2010 | 02:21 PM
Vlaze's Avatar
The Angry Wheelchair
This makes no sense. The root of the problem is the bracket has been spot welded, poor design. The problem is the brackets are breaking off at the weld, not the bracket snapping because it's not thick enough. Doing a full seam or even just stitch welds on it reinforces it properly and will not break unless you don't know how to weld or what you're doing.
Why you would not trust the proper fix when done correctly that fixes the root cause is beyond me.
Old Mar 25, 2010 | 10:51 AM
I don't understand the reason for being bashed here. I was expressing my personal opinion on the issue. After seeing how easy it was to bend the bracket in several areas after removing it, I feel that the reinforcement bracket is a much better option. Some may see it as overkill, but i can rest easy knowing it isn't going to break or bend again on me.
Old Mar 25, 2010 | 04:59 PM
Owner of BHR
Nobody is "bashing" anyone. You expressed your opinion, and I expressed mine. Given that I was the one who originally discovered the issue and developed a rather simple and effective solution (and one that you can have done locally for only a few dollars), a solution that has yet to fail when done properly, I felt like getting in on the discussion. Please also consider how many people have taken my advice and been satisfied with the results. Might you agree that experience plays a role in deciding which approach may be more valid?
Besides, as I stated earlier, I really don't care WHICH approach people take. I just hope they do something for themselves so as to save their transmissions.
Old Sep 7, 2010 | 11:15 PM
Beefy98's Avatar
So the S2 is different, not different....im guessing NOT different. Has Mazda even officially acknowledged the issue?
Old Sep 7, 2010 | 11:38 PM
DarkBrew's Avatar
Extraordinary Engineering
The spot welds DO NOT represent the structure of the clutch bracket. If you study the bracket it's obvious. Welding will help stiffen the structure but does not address the root cause of the failure.
This was discussed to death...
https://www.rx8club.com/series-i-trouble-shooting-95/clutch-pedal-snap-off-8-year-warranty-recall-%7E%7E%7E-132912/page37/
see photos here
https://www.rx8club.com/showpost.php...&postcount=921
Old Sep 8, 2010 | 08:12 AM
Race Roots's Avatar
Former Sponsor
...a solution that has yet to fail when done properly...
That is the key point, I had a reputable shop call me the other day saying I shipped the wrong sway bars and that they were the wrong sizes. They then continued to tell me it was no way it was going to be installed.
I then proceeded to tell them they had mixed the bars up and were backwards. I then emailed them installation instructions.
Go figure.
The thing is with anything is will it get done properly the first time? We cannot vouch for every "welder" out there that has shop on the local corner and can do it properly. I have seen excellent welding and then I have seen **** poor welding with pedals that have snapped.
Options are options and simply that, just need to make sure it is done right either route you take
Revision C is still the same pedal. If you are going to get it welded make sure it is done right. I had a customer pay $100 for a welding job that his ended up snapping on him again 4 months later.
Old Sep 8, 2010 | 08:23 AM
DarkBrew's Avatar
It's too early to tell if welding the pedal will be reliable.
The first clutch pedal issues I found in a search were around 2007 and seems to have started with aftermarket clutch users. Makes sense, yes?
The first welded brackets have probably not seen enough use to really know for sure.
https://www.rx8club.com/showthread.p...h+pedal+broken
This references other posts and another forum
Old Sep 8, 2010 | 10:24 AM
Owner of BHR
Go figure.
Shall we start a jointly-authored thread about the things with which we deal on a daily basis?
Old Sep 8, 2010 | 10:28 AM
Owner of BHR
No, it isn't too early. I have been welding them and suggesting the welding for two years without further failure on part of those properly welded pedal assemblies. A "proeprly-welded" pedal assembly is one that is welded BEFORE the damage occurs. The self-annointed engineers and brainiacs around here can argue all about the physics, mechanics, and design (and I will agree with them on those matters) but the simple fact is that my suggestion, for some strange reason, works. Add to it Race Roots bracket and you have one pretty solid pedal.
Old Sep 8, 2010 | 10:54 AM
DarkBrew's Avatar
That would be awesome. Can you get Jeff to join in?
Overkill FTW!
I was lucky and had the clutch pedal replaced for what turned out to be a squeaky switch (awesome Mazda Tech troubleshooting).
The reinforcement bracket adds enough stability to be a great mod even without the bracket failure issue.
Those welding their own pedals and not using the bracket would be wise to add metal to the two upper bolt hole areas and up into the structure where the typical metal fatigue cracks occur.
Old Nov 11, 2010 | 01:44 PM
corres78's Avatar
I did my own version for my 05 RX-8 four months/2000 miles ago
Old Nov 11, 2010 | 08:53 PM
Owner of BHR
Those welding their pedals and not using the bracket would be wise to add metal to the two upper bolt hole areas and up into the structure where the typical metal fatigue cracks occur.
Have you ever actually SEEN a BHR-welded pedal assembly? Even if only in photos?
Old Nov 11, 2010 | 09:55 PM
DarkBrew's Avatar
May have seen a pic... I remember really nice welds just like the mid pipe.
I do know WCS and he keeps threatening to drag me up to install his. When I get to touch it I promise I will send you my impressions.
BTW, I'm looking forward to an ignition upgrade in the spring!
Old Nov 12, 2010 | 07:13 AM
Owner of BHR
The welding that you are suggesting be done is already exemplified by our offering, and has been for a couple years.
Old Nov 12, 2010 | 08:46 AM
DarkBrew's Avatar
My comments were directed towards the people who grasp without thought for the cheapest, easiest band-aid solutions.
BHR is well known for quality, commitment and passion.
I know that you back your products and take great pride in them
Old Nov 12, 2010 | 09:37 AM
Owner of BHR
SilverEight posted a couple photos of properly-welded clutch pedals on "Rotary4Life.com". One was his own and the other was a BHR version.
What I find fascinating about all this clutch pedal talk is that the welding process is a rather inexpensive preventive measure, yet people still wonder if they should bother with it. Welding and Race Roots' bracket, combined, is said by those who use the combo to be a pretty solid set-up.
Old Nov 12, 2010 | 10:15 AM
DarkBrew's Avatar
You can gift wrap a zero risk solution and offer it for free and people will still find reasons not to adopt it.
Old Nov 12, 2010 | 05:45 PM
Owner of BHR
Very true!
