Upper radiator hose ID? (Water temp adapter)
Old Feb 27, 2010 | 05:34 PM
hakuna matata!
I'm looking to buy a water temp adapter for a gauge setup.
I'm curious as to what size water temp adapter people buy (excluding the racing beat) for the upper radiator hose? I was reading that 34mm might leak? So I can get a 36mm adapter but in that case would the upper radiator hose accomodate that? Is there enough give?
Old Feb 28, 2010 | 04:22 AM
hakuna matata!
bumpie ;[
Old Feb 28, 2010 | 06:50 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Gotta ask.......since it's available on the OBDII port.......why not just get the reading from there?
Old Feb 28, 2010 | 02:00 PM
Did you try searching? I've seen pics of that style adaptor posted on this site.
Old Feb 28, 2010 | 02:01 PM
hakuna matata!
Pics, thats all they are. Problem is the Prosport makes those in 34mm or 38mm. I'm not sure which people are using.
And Mazurfer, yeah I usually do that with my AP but I can get rid of that all together by having true gauges
Old Feb 28, 2010 | 02:04 PM
I may be draining mine today. Will check if I do. Should be able to just measure the neck which won't lose/require much coolant if you want to do it yourself.
Old Feb 28, 2010 | 02:38 PM
hakuna matata!
I'd really appreciate that
Old Feb 28, 2010 | 03:19 PM
It's 34mm at the water outlet...
If you put an adapter in an old hose..it will be stretched..so you should use a silicone or a new hose
Old Feb 28, 2010 | 05:37 PM
Mazurfer's Avatar
Yeah, after I wrote that I saw you had an AP and figured that was at least going to be some of the reason for you interest.
Old Mar 2, 2010 | 03:03 AM
Sorry, only got it off tonight and what dannobre said
mine doesn't really seemed stretched much if any
Old Mar 2, 2010 | 08:27 AM
TheWulf's Avatar
My 8 looks like a Smurf
If you're worried about leaking you could always add small T-clamps.
Old Mar 2, 2010 | 10:00 AM
it should be 34mm
Silicone hose doesn't not stretch. at least the Japanese one I got does not. it was a nightmare trying to fit it in ...
Old Mar 2, 2010 | 11:05 AM
Stock lower hose on mine at about 50K miles was stretched to over 38mm in the middle....
That's why I recommended silicone ones...they don't stretch out like the stock rubber ones do
Digitz0070
55
Jul 25, 2017 08:40 PM
Evan Gray
Nov 24, 2015 01:00 AM
FubarI33t
Sep 28, 2015 08:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Digitz0070
Sep 25, 2015 10:58 PM
