Can I get Mazda to aprove this ?
Old Jan 22, 2004 | 09:04 PM
Maestro's Avatar
Hmmmmmmm
Old Jan 22, 2004 | 09:11 PM
Lock & Load's Avatar
Talking
Maestro
Nice piece of plumbing visually appealing but does it have any real benefits????????????
Michael
Old Jan 22, 2004 | 09:14 PM
Hymee's Avatar
Race Steward
Hehehe.
It is an intercooler, and those are only normally used with forced induction. What I cant tell from the picture is what form the compressor takes (i.e. supercharged, or turbo charged).
I looks faster Michael - you know just how Yellow ones look faster than Red ones, yet Red ones are actually quicker
Cheers,
Hymee.
Old Jan 22, 2004 | 09:55 PM
Maestro's Avatar
Knightsport Supercharger Kit.
Makes 280ps @ 4-5 psi :D
Old Jan 22, 2004 | 10:03 PM
Talking
Are we talking 206kw woah .
HOW MUCH , WHEN WERE ???????????
Old Jan 22, 2004 | 10:39 PM
Maestro's Avatar
Thats the test car.
I'm actually gonna get one over here and see if I can get Mazda it support it as a dealer accessory.
The Nissan has how many kw you say ????
Hmmmm oh and a maxima chassis :P
Old Jan 23, 2004 | 07:56 AM
Kev's Avatar
Kev
[rapidus octus]
Anybody would think you guys have got something against the under bonnet tupperware look!
So that's 4~5 psi ... then we're talking standard rotors and other internals?
I'd expect it could be tweaked a bit further with some internal work.
Do you know what they've done with engine management and exhaust?
Old Jan 23, 2004 | 03:05 PM
Maestro's Avatar
Nope this is where the journey begins.
Some guys I know from a kiwi rotary forum got to go for a drive in the test car.
There are also some crazy turbo ones from RE Amemiya.
Give me some time I will get tpo the bottom of it.
But my thoughts would be 280hp @ 4-5psi 'should' be able to keep the stock ecu.
'should' be able to
Old Jan 23, 2004 | 03:33 PM
takahashi's Avatar
The Blitz compressor does about the same increase and they said you can keep the stock ECU too. Why not pay a 1000 bucks more for a tunable one from Ric? I just wonder tune it better with Ric I will get much smoother h-t curve.
Old Jan 23, 2004 | 03:38 PM
NT Rotor Head's Avatar
Guys, would the stock ECU even have fuel and ignition mapping to support forced induction of any sort, even low PSI? I'm not sure that it would. A tuneable aftermarket ECU may be required to cater for positive pressure! Any thoughts?
Old Jan 23, 2004 | 06:10 PM
garbagedook's Avatar
is that 280 hp at the wheels or at the crank?
Thanks.
Old Jan 24, 2004 | 02:00 AM
Kas's Avatar
Kas
- Senior Menber -
you'd hope its wheels.
Old Jan 24, 2004 | 07:38 AM
Hymee's Avatar
Race Steward
A PS is not exactly the same as a HP, but pretty close:
hp
According to the most common definition of horsepower, one horsepower is defined as exactly:
1 hp = 745.69987158227022 W
The horsepower was first used by James Watt during a business venture where his steam engines substituted horses. It was defined that a horse can lift 33,000 pounds with a speed of 1 foot per minute: 33,000 ft·lb·min-1. (This is equivalent to approximately 15,000 kg at 30 cm.)
PS
This unit (German: Pferdestärke = horse strength) is still commonly used in Germany and central Europe, although not an lawful unit any more. It is defined by the Physikalisch-Technische Bundesanstalt (PTB) in Braunschweig as:
1 PS = 735.49875 W
PTB http://www.ptb.de/
Source can be read at http://en.wikipedia.org/wiki/Horsepower
Nice mod. I would like to play with positive displacement forced induction on a Rotary
Cheers,
Hymee.
Old Jan 24, 2004 | 11:09 PM
Wildcard's Avatar
NT Rotorhead
My thoughts too. I've read elsewhere that the stock ECU does not have any maps for FI.
Old Jan 26, 2004 | 07:24 PM
Dez's Avatar
Dez
abcdefghwakeupneostuvwxyz
how odd that am American hours was able to pull more than German hourse?
--dez;
Old Feb 3, 2004 | 01:31 AM
rotarygod's Avatar
If they were both WWII horses then the answer should be obvious!
Old Mar 19, 2004 | 01:02 AM
MazdaManiac's Avatar
I did the math in another thread (forgot where and I forgot the actual numbers), but I calculated that the OEM injectors will support about 310 crank HP.
I don't think the PCM will know what to do with that much air, but a piggy-back like the E-Manage can turn on the fuel delivery for the 3 or 4 PSI that would yield that kind of HP.
Old Mar 19, 2004 | 05:58 AM
nismo350Z's Avatar
you meant horse, Dez? probably due to different breeds.... just j/king...
BTW, what's the differences between BHP and HP?
cheers,
richie
Old Mar 19, 2004 | 03:16 PM
wallerc's Avatar
BHP = brake horsepower. As there are four of them BHP is more than HP.
Old Mar 19, 2004 | 03:49 PM
:p
Old Mar 19, 2004 | 04:44 PM
takahashi's Avatar
According the lastest Option Japan Magazine that Kight Sport Supercharger is 285 ps at crank. Nodel Ni PE3000 Supercharger.
Trust makes turbo Re-Amemiya has 260ps with TD06-18G turbo with retune ECU (REDOM v. 2)
Should be more later on!
Old Aug 11, 2004 | 12:02 AM
Maestro's Avatar
I have one here in NZ for sale........ Finally :P
Old Aug 16, 2004 | 04:34 AM
rotarenvy's Avatar
how much?
czr
Sep 13, 2015 11:37 AM
erikcamacho15
Sep 12, 2015 11:23 AM
