high flow cat
Old Feb 18, 2010 | 07:18 PM
mr_a2z05's Avatar
high flow cat
I got some problems with my OEM cat and wanted to put a high flow or performace cat on it but don't quite know where to get it. any ideas?
Old Feb 18, 2010 | 07:35 PM
Covered for 80k miles under warrenty.
You can try the RP cat butt... there have been alot of failures.
http://www.rx7.com/store/rx8/rx8exhaust.html
Old Feb 18, 2010 | 08:00 PM
Bigbacon's Avatar
2006 WB AT
what kind of failures?
Old Feb 18, 2010 | 08:04 PM
mr_a2z05's Avatar
studdering problem, checked everything and thats the last thing it could be but dont know if it falls under warranty cuz i bought the car from a non Mazda dealer used. its a 2004.
Old Feb 18, 2010 | 08:23 PM
Bigbacon's Avatar
2006 WB AT
the cat warranty I think is a USA thing, not a mazda thing. If the cat is bad and you are not over 80,000 then you are covered and can get a new one.
Old Feb 21, 2010 | 02:34 PM
mr_a2z05's Avatar
i took it to the dealer and they said its not the cat so im kinda out of ideas. they dont even know whats causing the power loss.
Old Feb 21, 2010 | 02:44 PM
loss of power is usuallly caused by a few different things so you really need to approach this with a 'process of elimination' mentality
Clogged Cat? : check
Ignition Coils: How old are your coils? ever replaced them?
Spark Plugs: how old are they?
Are you getting a CEL of any kind or even the ocassional blinking CEL?
if you've ruled out the CAT as a problem and it's not ignition related then it could be a compression issue. The only way to be certain is to have a compression test done.
your engine is warrantied 8 years, 100,000 miles.
Old Feb 21, 2010 | 02:47 PM
Easy_E1's Avatar
EPA Emissions Warranty LINK
Sounds like as Jedi mentioned, it's time for a compression test.
Old Feb 21, 2010 | 02:55 PM
mr_a2z05's Avatar
replaced ignition coils a week ago, spark plugs about 6 months, and i got the CEL P0410 but they didnt find anything wrong with that either. only told me to bring it back if the light comes on again.
WranglerFan
Aug 21, 2022 01:29 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
Hiroshima_RX
Sep 21, 2015 06:28 PM
