newbie.. how do u take off the center top the dash
Old Feb 4, 2010 | 10:10 PM
quicksilver34's Avatar
LIFE IS GREAT
how do you take off the center top of the dash, cuz i want put my gauge pod on but idk how to take it off.. if someone can help please
Old Feb 4, 2010 | 10:20 PM
Alexb's Avatar
desperately needs a drop
There are DIY's that include this info.
A carPC DIY would. Or there is one about the complete navigation system.
Go look for one of those, because there are a whole lot of steps and most really need a picture to explain them.
But it basically involves taking the shift boot piece off, the ashtray out, the stereo out, the vents out, then you can take it off.
Old Feb 4, 2010 | 10:27 PM
LIFE IS GREAT
oh man that alot just to get to that thing
Old Feb 4, 2010 | 11:23 PM
LIFE IS GREAT
if anyone have has pics or how to do it let me know
Old Feb 5, 2010 | 01:55 AM
rotarykillz's Avatar
Rotary Freak
There are pics out there. I've removed it before. You have to remove the whole head unit, starting at the bottom of the console and work your way up.
Google Mazda RX8 CarPC install DIY and you should find pics and walk throughs.
Old Feb 5, 2010 | 01:56 AM
Rotary Freak
I remember there being one that wasn't on rx8club.com that me and my brother used but can't remember and am too tired to look for it Its out there though
Old Feb 5, 2010 | 03:16 AM
PhantomRX-8's Avatar
Bad Ass
Its really not that hard man. If you can add 1+1+1 then you should have no problem doing this. I know it looks intimidating because it is so well put together, but after youve taken this car apart a couple of times, you realize its just like every other car. Just make sure you pull up on the shifter piece as straight as possible. Makes for undoing the latches much easier. As soon as you have the shifter plate off, you see the screws for the ash tray. Remove those and the ash tray slides out, revealing the screws for the radio! Remove those screws and unclip the harness' and guess what, it reveals the screws the vent! Remove those screws, slide the vent out, and then....YES, it reveals the screws for the center piece!!! Remove those, and unclip the 3 or 4 clips and your golden.
Old Feb 5, 2010 | 05:20 AM
chrism's Avatar
Misfit Moderator TnC
you have to start from the center console/shifter and work up.......the radio has to come out as well but DO NOT forget to remove the "jesus" bolt......you will understand the terminology when you get to it because it is way back behind the radio cradle.....if you just yank your radio out without removing that bolt you can say goodbye to your radio and hvac......if you done it a few times it might take you 30-45 minutes.....first time is tough though
Old Feb 5, 2010 | 09:12 AM
LIFE IS GREAT
The Jesus bolt wasn't bolt on my car..
And my air vent has no screw.. it all werid from
My friends car and yes I'm first owner
But umm I'm try and slide the vent off
Thanks for ur help guys.
Old Feb 5, 2010 | 09:33 AM
ninjajim4's Avatar
just fyi, you don't have to pull the radio out entirely, nor undo any of the harness going to it. you can just slide the radio out far enough to get at the 2 vent screws. i guess it's not a big deal but for me the hvac harness clips were the toughest to get out for some reason...
pretty funny about that jesus bolt... i am debating on leaving it out for my own convenience or putting it back to screw any future thieves
Old Feb 5, 2010 | 02:10 PM
ZOOM-I-DO's Avatar
Here is my DIY for Lo-Tek gauge pod install.
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-lo-tek-pod-prosport-digital-gauges-188900/
I also used the web site that Rotarykillz was thinking of.
http://www.whatsmyip.org/ipodrx8/1.php Very good pics.
Here is another Gauge DIY install.
https://www.rx8club.com/showthread.ph...ge+pod+install
Picture Album her on RX8club.com
https://www.rx8club.com/members/zoom-i-do-54105-albums-lo-tek-gauge-pod-mod-1870/
And Ninja is right, you dont need to pull the radio out all the way.
Good luck
Old Feb 5, 2010 | 02:16 PM
Mr.We$t's Avatar
Rx-8 the protege
The air vents should have 2 screw once u take them out use extra force and they will pop out! Pull it straight toward u! Then there are 2 more screws attaching the top unscrew them and pull the center up it won't break it will pop out! There is a YouTube video on it aswell
I did my gauges last night came out very nice!
Old Mar 21, 2010 | 04:21 AM
mopiko's Avatar
do u have to remove the radio, to access to the air vent?
Old Mar 26, 2010 | 09:56 PM
tubingchamp's Avatar
What mawd bug?
Good photo of hidden screw.
Had issues finding it today... Haha
Old Mar 26, 2010 | 10:24 PM
Mr.We$t's Avatar
Rx-8 the protege
Hay quick there's actually a YouTube video on it that helped me alot!!!! I'll try and get it for u
Old Mar 26, 2010 | 11:17 PM
LIFE IS GREAT
I saw that one and it did help
ShellDude
Oct 1, 2015 09:55 PM
archon
Oct 1, 2015 06:08 AM
FubarI33t
Sep 28, 2015 08:45 PM
drlubell
Sep 26, 2015 11:58 PM
