Stalling when fuel @ 1/8
Old Dec 4, 2009 | 08:56 PM
dirtybirk's Avatar
GA Stalling when fuel @ 1/8
04 GT, 6 SPD, 45000 miles. Just recently the car stalls when going around corners, going up hills or accellerating hard when the car is low on fuel. However, it is not low enough to cause the low fuel light to come on. When I get fuel it will only take 12 gallons to fill up. So, there is almost 4 gallons of fuel remaining in the tank. The car runs fine when the fuel level is above 1/4 tank. Any ideas would be appreciated.
James
Old Dec 4, 2009 | 09:05 PM
expo1's Avatar
He's as bad as Can
I learned about this at Watkins Glenn elevation changes, sharp turns, high RPM's, low fuel and the saddle bag type fuel tank can cause this. I just make sure I never hit the track below 1/4 tank. If your having this issue with more than a 1/4 it can be a fuel pump issue.
Old Dec 4, 2009 | 09:08 PM
I8U's Avatar
I8U
Fuel pump failing...
Old Dec 4, 2009 | 09:19 PM
expo1's Avatar
He's as bad as Can
I would only say that if he has this issue with more than 1/4 tank. I was towards the end of a 45 minute session and my fuel light came on. I was getting fuel starvation when going into THE BOOT . With more than 1/4 tank no issues and my first fuel pump lasted long after that event. But I do know of other members that have fuel starvation issues under less extreme conditions and for them a fuel pump problem is most likely the cause.
Old Dec 4, 2009 | 09:28 PM
I8U's Avatar
I8U
I had the same problems myself back in March. A new fuel pump fixed the issue. Others have had starvation issues, I just don't think that is the issue dirty is talking about. It really does like the beginning faults of a failing fuel pump.
Dirty, look into replacing the pump soon. The frequency of the stalls will increase as the pump gets worse and soon it may start stalling even after a short 20 min trip. I only speak from my experience, though.
Old Dec 4, 2009 | 10:33 PM
yep.
Old Dec 4, 2009 | 10:47 PM
*sigh*
search ...
Old Dec 4, 2009 | 11:40 PM
SayNoToPistons's Avatar
Wheels, not rims!!
I went below the E line way after te fuel light came on three times already. Thought it was going to break down but it never did and started just fine. Dangerous game
Old Dec 5, 2009 | 09:22 PM
dirtybirk's Avatar
GA
The only time I run into this problem is when the fuel is below an 1/8 of a tank. About 2 months ago I ran it until the low fuel light came on and I didn't notice this problem. But then again I wasn't hitting the corners hard as I was on my way to the gas station.
James
Old Dec 5, 2009 | 09:27 PM
It will start out low and as the pump craps out or your speeds increase it will get to the point it will do it at 3/4 tank
Stupid fuel pump
Old Dec 5, 2009 | 10:15 PM
I8U's Avatar
I8U
yep
Old Dec 10, 2009 | 12:10 AM
Stupid fuel pump
ding, ding, ding. we have a winner..
and left hand turns are a bitch.
Old Dec 10, 2009 | 12:12 AM
and every time you do that you overheat the pump.. the pump does not like that..
been there done that, have dead pumps to prove it.
Old Dec 10, 2009 | 12:52 AM
Easy_E1's Avatar
Time for a new fuel pump.
Old Dec 15, 2009 | 02:49 PM
Buckeye_rx8's Avatar
Fuel pump suggestions? Brands to avoid? Best Fix for this issue?
Old Dec 15, 2009 | 02:51 PM
http://blackhaloracing.com/products-...ce-fuel-pump7/
Old Dec 15, 2009 | 03:27 PM
Thanks for the link. I actually found the thread I was looking for by searching "fuel pump solution"
Who knew that the "search" function actually works...
Hunterkelley24
Jun 14, 2022 08:32 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
