lost of power whlie driving..
Old Nov 20, 2009 | 07:37 PM
stx0174's Avatar
hey guys, can anyone help me with this problem that i'm having?......some times when i drive my 8 it seems to lose power when i step on the gas. and b4 its cut off its start to shack very hard and off it goes....any info will help me to fix this prob.
Old Nov 20, 2009 | 07:40 PM
chino0314's Avatar
Year, mileage, mt or at.
When did yu change coils, plugs wires
Old Nov 20, 2009 | 08:01 PM
Lebren's Avatar
RX8club group buy vendor
if it was the cat the CEL should come on, unless the cracked part was after the 2nd O2 sensor.
Old Nov 21, 2009 | 05:04 AM
AJ's Shinka's Avatar
Enthusiast
I just had this, it was my plugs. Not that it can't be other things but check your plugs.
Old Nov 21, 2009 | 05:57 AM
@!!narotordo's Avatar
FLAME ON!
Yup plugs are clogged cat. Start with your plugs and coils then work your way down. GL!
Old Nov 21, 2009 | 08:53 AM
04RX8man's Avatar
Rotary Powered Countryboy
coils/plugs...
Old Nov 21, 2009 | 11:03 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Here we go again!
Old Nov 21, 2009 | 12:44 PM
stx0174's Avatar
year-05 mil-20k n change AT. I had my plugs changed b4 but not my coil..wat does CAT means?
Old Nov 21, 2009 | 01:09 PM
shazy's Avatar
Catalytic converter.
It's the middle piece of the exhaust system that makes you pass the Smog Test.
Old Nov 21, 2009 | 04:52 PM
Mazurfer's Avatar
Given your new input.
In my opinion only.
I'd first make sure all plug wires are good and tight at both ends.
Then I think I'd go after all the coils.
If still no good, then it's time to look maybe at the MAF and then the CAT.
New term........MAF = "Mass Air Flow" it's a sensor in the air intake accordion tube.
Old Nov 23, 2009 | 09:30 PM
stx0174's Avatar
ok guys, but i was wondering. can it be a bad fuel injector? casue it happens after i drive for a short period n come to a complet stop at a light. just wondering
Old Nov 23, 2009 | 09:39 PM
stx0174's Avatar
Question
Old Nov 24, 2009 | 01:57 AM
Lebren's Avatar
is there something pointing you to an injector, recent work done etc?
Old Nov 24, 2009 | 04:39 AM
Jon316G's Avatar
Grasshopper
+1.
What everyone is telling you above is a good starting point because we've seen similar symptoms that resulted in a clogged cat or bad coils/wires/plugs.
Rule out the common issues first and then we can move on from there if needed.
Old Nov 24, 2009 | 06:39 AM
Huey52's Avatar
Registered Zoom Zoomer
I changed out my '05 coils at ~20k and would also lean to them as the culprit. Good way to eliminate a variable as well. Easy to change your coils yourself, see the DIY by dozer.
Old Nov 25, 2009 | 12:52 PM
stx0174's Avatar
ok..How would I know if it is my coils that is bad? would it look burnt or what? I know im asking mad questions, but im new to this and i love my 8 so i want to be sure im doing the right thing.
Old Nov 25, 2009 | 12:55 PM
RIWWP's Avatar
Nope. Actually, if the coils look burnt, your engine probably wouldn't run
There is no other indication than one or more of the following:
- Unstable idle
- Loss of power in low RPM ranges
- Loss of power in high RPM ranges
- Mis-fires
- over 20,000 miles since your last coil change (some last to 35-40k, but even that is uncommon)
And of course this is always present:
- Back to running perfectly when you replace them
Old Nov 25, 2009 | 01:43 PM
Huey52's Avatar
"A search a day keeps the flamers away", but here you go.
File Type: pdf
Old Nov 29, 2009 | 04:07 PM
stx0174's Avatar
would bad coils cause the car to vibrate????
Old Nov 29, 2009 | 09:04 PM
Old Rotor's Avatar
Yes it is possible.
Old Nov 29, 2009 | 10:13 PM
FLAME ON!
Check your spark plugs. I had this happen to two friends of mine.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
p8ntman442
Sep 23, 2015 09:18 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
