Oil gauge idea?
Old Nov 12, 2009 | 07:51 PM
rotarymike's Avatar
Oil gauge idea?
I've done my due diligence and read the various oil-gauge-is-a-fake threads.
What I've found is that the gauge is given information by the CAN bus. The ECU basically tells the gauge to sit pretty at a little over half.
If this is the case, why not make a device to tell the gauge via CAN bus to read something else? It doesn't seem to me that a PIC or similar setup to intercept the CAN signals, repeat those not relevant, and replace the OP signal with it's own, derived from a simple pressure sender (most of which are resistive).
Am I missing something? Does this already exist?
A device like this would also possibly make the water temp gauge a real one too.
Old Nov 12, 2009 | 10:56 PM
b'Eight''s Avatar
Yeah, I've been wondering about this too. It would be cool to make the oil pressure gauge full functioning. I believe the water temp gauge already is. I can't see why this couldn't be done?
Old Nov 12, 2009 | 11:10 PM
Too bad there are no specific readings on it and honestly looking at the pressure sensor it appears to me that it's and on/off switch. There is either pressure or not. For $100.00 you could have a real nice accurate gauge.
Old Nov 13, 2009 | 08:48 AM
rotarymike's Avatar
True, but the RX8 interior does not lend itself to gauge mounting. The RB piece is WAY out of the line of sight, and bloody expensive for a piece of plastic. No pillar mounts because of the airbag. I've not seen a hood for the radio area that looks remotely stock. I could just screw some gauge cups to that piece, but same problem. I've tried finding a navi-equipped hood without the navi stuff installed, but no dice.
I'd be happy with a left-is-zero, right-is-100psi sort of gauge. I don't really need numerical accuracy - I want to see it if it's notably low or drops suddenly (if, say, a rock gets through the mesh and oil cooler).
The water temp, OTOH, I'd like to be somewhat accurate. The ones in my 88 RX7 and my Jeep are good enough to see when the thermostat opens.
No one on the forums has any experience with CAN bus?
Old Nov 14, 2009 | 07:07 PM
04RX8man's Avatar
Rotary Powered Countryboy
the water gauge has a "window" not sure of the number but it it's between certian temps it's in the normal spot...above or below that window it move either way...
I've seen pleny of ppl with apillar gauges and y not try the ashtray pod? possibly the AP( I'm not sure if it reads Oil Press. but someone with the AP will have to chime in and see)
Old Nov 14, 2009 | 08:19 PM
b'Eight''s Avatar
Because he wants to make the stock oil press gauge work. Doesn't matter his reason. What we want to know is if it is possible and if so, how? Anyone care to add?
Old Nov 14, 2009 | 09:12 PM
I8U's Avatar
I8U
The airbag is located above the window...there is nothing behind the a-pillar. There are a few companies that make a-pillar pods for the 8 in 2 or 3 pod styles.
Old Nov 14, 2009 | 10:46 PM
TX
Check this out!!
https://www.rx8club.com/series-i-tech-garage-22/oil-temperature-gauge-auber-instruments-186061/
Old Nov 15, 2009 | 09:20 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
You could always do this, coupled with the RB oil pressure/oil temp adapter.
https://www.rx8club.com/series-i-interior-audio-electronics-24/vent-pod-gauge-installed-163434/
And....................... if you go just want to go with the vent pod and RB adapter but not the rest, I have a gauge that will drop right in it.
https://www.rx8club.com/showthread.p...89#post2797989
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
drebbrnator
Dec 27, 2018 07:02 PM
RicerX1
Jan 11, 2016 05:59 PM
talonhart2
Aug 26, 2015 04:14 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
