ECU Download
Old Nov 8, 2009 | 06:58 PM
Herry's Avatar
Smile ECU Download
Hi guys,
Does anybody know how can I download ECU data from my car? I bought a sCANalyser Pro Tuner‏ last week, but I didn't include ECU downloader.(Of course, they will send base ECU data to me.) But, I want to store my original data.
Help me !
Old Nov 8, 2009 | 07:42 PM
StealthTL's Avatar
A Cobb AP will do that......kinda.
S
Old Nov 8, 2009 | 10:53 PM
Herry's Avatar
thanks guy, But I already bought Hymee's sCANalyser Pro Tuner. I want to download ECU data using this hardware. Can u recommend any programs?
Old Nov 9, 2009 | 12:10 AM
(paging Brettus or Hymee)
Old Nov 9, 2009 | 01:14 AM
Kane's Avatar
Gotta give Hymee your PCM ID and he will send you the factory tune.
Old Nov 9, 2009 | 07:17 AM
That's not what he's asking for
paging Seikx8 .....
Old Nov 9, 2009 | 08:40 AM
Herry's Avatar
Thanks, I already sent P.M. to Seikx8.
Old Nov 9, 2009 | 08:44 AM
Herry's Avatar
Unhappy Mazda Module Programming
I found "Mazda Module Programming". Where can I download it, please? Someone should give I advice. please ..
Old Nov 9, 2009 | 02:04 PM
Hymee's Avatar
Race Steward
MMP (and even the full dealership/workshop tool) does not provide a function to read the ECU contents in this manner. This is possible using my stuff, but I have not released this functionality yet. So far it has not been a big drama, as I can either get the "standard files", or for Pettit owners I can get the file that was used for each car via an arrangement with Cam.
Cheers,
Hymee.
Old Nov 16, 2009 | 07:41 PM
Herry's Avatar
Hi guys,
I live in South Korea. Do not exist MAZDA in my country. So I imported my RX-8 from JAPAN last year. JDM RX-8 has a problem that it can't over 180KPH. I'd like to remove this speed limit.
I was firmly resolved, bought sCANalyser Pro Tuner for remove it.
I have tried to put ECU data 3 times.
1st time, I was putted ECU data that It was original data. No problem.
2nd time, I changed only RPM limit to 9500RPM. Yes, No problem too.
3rd time, I changed SPEED limit. I couldn't start my car.
I tried to find any information on internet and this forum. I couldn't find useful information. I don't have any method. So, I wanted to download my ECU full data like RX8_PGM.
I think, my ECU is dead.
I have a problem. Because I can't set immobilizer in my country when I'll buy new ECU from JAPAN. But I'm not give up yet. Because, my RX-8 is very precious for my life.
Please help me .
Old Nov 16, 2009 | 07:52 PM
RIWWP's Avatar
I highly recommend working directly with Hymee. The no-start issue is probably something reversable with the software you have.
Also, no one has yet been able to remove the speed limiter for the RX-8s with automatic transmissions. The manual transmission RX-8s do not have speed limiters.
Old Nov 16, 2009 | 08:02 PM
Herry's Avatar
Thanks, I'm working directly with Hymee, now. But, I want to get more useful information. And I have Japanese version RX-8 that it can't over 180KPH.
Old Nov 16, 2009 | 08:34 PM
MazdaManiac's Avatar
Not true.
I can remove it on all models EXCEPT the USDM AT models.
Addressing it on the US models is in the works.
Old Nov 30, 2009 | 08:53 PM
Any update?
Old Dec 1, 2009 | 06:50 PM
Herry's Avatar
Unhappy Vcm
It is yet to be solved. I bought Ford/MAZDA VCM on the recommendation of Hymee. I received it yesterday morning. But, VCM couldn't connect to my car(Start New Session -> All Other). "Manual Vehicle Entry" didn't, either. Of course I updated it. (IDS is 6.16, Calibration is C63) And, I couldn't find RX-8 on VCM support car list.
I was gonna ask MAZDA Japan for help. But, MAZDA Japan said, they couldn't hlep me.
Old Dec 6, 2009 | 09:20 PM
Can the Cobb Pro Tuner version do this?
Jeff?
Old Dec 6, 2009 | 09:33 PM
Sorta.
However, if he has already broken his OE ROM, it may be missing important data (like the cluster match, the "as build" or the imobilizer registration) that nothing will fix other than the Mazda-authorized M-MDS.
Old Dec 6, 2009 | 10:41 PM
Brettus's Avatar
Boosted Kiwi
Import a speedo cluster from an early model 8 ,that has no immobiliser, from Japanese wrecker along with the pcm .
Sorry - that is all I can think of ....
Old Dec 6, 2009 | 10:46 PM
Sorry, sounds very troublesome since there is no Mazda in Korea. Not to mention the language barrier.
Old Dec 6, 2009 | 10:50 PM
Brettus's Avatar
Boosted Kiwi
Lets confirm that it is in fact dead as a first step .
What happened exactly - what did you do the erase the computer memory ?
Old Dec 10, 2009 | 02:41 AM
Herry's Avatar
Exclamation ECU swap
I din't understand why it was erase. I didn't any action when I was writing it.
Guys, I have new question. I found another AT spec's ECU. However my RX-8 is JDM 6MT. I have VCM, and it can re-programm ECU. Can I use AT spec's ECU on my car when I'll re-programming it?
Old Dec 10, 2009 | 02:53 AM
kevk's Avatar
From: in virgina right now want to go back to texas
Question
Originally Posted by MazdaManiac
Not true.
so what are they limited too my 6speed manual has gotten up to about 140 -141 before i had to slow it down due to road conditions and is the manual limited?
Old Dec 10, 2009 | 03:03 AM
no limits on the six speed.
146 to 148 is where the fun ends.. and the fun ends in 5th.
Old Dec 10, 2009 | 03:08 AM
Herry's Avatar
Pcm inspection
I found some different connector from MT on MAZDA service manual. 4AT ECU didn't have these.
- APV position sensor power supply
- Fuel injector (FP2) control
- APV opening angle
- VFAD control
If I'll re-program AT ECU to MT ECU, can I use these ports?
Old Dec 10, 2009 | 03:20 AM
Only on North American models.
European and Asian models are limited to 131 MPH.
No - They are physically different.
The AT PCM is missing the controls for the actuators you mention as well as the 3rd set of fuel injectors.
