Abs light + skid light!
Old Nov 8, 2009 | 06:00 PM
Mast3rpaco's Avatar
HI,
I have this small issue with my 04 MT rx8 . Whenever I start the car and press on the brake pedal I have the abs light and skid warning light open. They stay open and I dont know what exactly is the problem. I dont feel anything in the way the car drives but wanted to know what can possibly be the issue. Also, my rear break lights wont work so people dont even know Im braking. Since it happened my cruise control also wont work.
Anyways, Ill appreciate if someone can help me out here before I bring it to the stealership.
Old Nov 8, 2009 | 06:03 PM
shaunv74's Avatar
Power!!
The first thing I would do is make sure it's not just looking for your to calibrate your steering wheel. when you start the car turn your wheel all the way left then all the way to the right and see if the light goes off.
As far as brake lights check to see if you have bulbs burned out or bad switch under the pedal. Else I would take it to a local mechanic you trust. It may just be a short somewhere in the circuit and any mechanic can fix that for you.
Old Nov 8, 2009 | 06:13 PM
dozer's Avatar
on his 3rd rx8
make sure your batter post are on connected right
Old Nov 8, 2009 | 06:17 PM
shaunv74's Avatar
Power!!
Originally Posted by dozer
make sure your battery post are on connected right because I cannot spell due to looking at ***** all day.
Fixed.
Old Nov 8, 2009 | 06:23 PM
dozer's Avatar
on his 3rd rx8
^thank you, im on the tipsy side right now
Old Nov 8, 2009 | 06:51 PM
Mast3rpaco's Avatar
I already tried turning the steering wheel like you said and nothing. As for the break light I just changed them 2 months ago...
Any other idea?
Old Nov 8, 2009 | 07:00 PM
Mast3rpaco's Avatar
Just a picture of what I see...
Old Nov 8, 2009 | 07:59 PM
shaunv74's Avatar
Power!!
ABS light and brake lights out. Sounds like there's something going on with your ABS system or brake sensors. I'm not sure. You should probably go to the dealer to have them check it out. Other option is to get a OBDII CAN code reader and check to see if there are any error codes in the PCM.
Autozone could probably check for you.
Old Nov 17, 2009 | 11:02 AM
velocity-z's Avatar
whoa! another similar but not exactly same experience...
https://www.rx8club.com/series-i-trouble-shooting-95/abs-airbag-traction-control-light-186362/
anyone found the cause or fix yet?
Old Dec 26, 2009 | 12:43 AM
shinka911's Avatar
dude im having the exact same problems with the lights cruise control and brake lights not working ive been trying to fix it for over 3 months. it makes your abs and traction control not work btw
Old Dec 26, 2009 | 12:46 AM
shinka911's Avatar
https://www.rx8club.com/series-i-trouble-shooting-95/abs-traction-control-help-188028/
this is my thread
RX-8 Racing
20
May 14, 2016 06:25 PM
GK1707
Sep 27, 2015 07:33 PM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
