How Kane and Ray build a Ceramic, Ported, Turboed Renesis!!!!
Old Nov 3, 2009 | 11:17 PM
Kane's Avatar
Welp - after some big big help by AZRR with a last minute save; it is time to start this thing....
Ok; so here is my story.
May 2009 - I'm getting some misfires from the BHR coils - Ray flies to HI to install a NOS kit in another car; and looks at my misfire issue; thinks maybe one of the wire connections is soft; mails me a new one..... I install new wire - still have some misfiring at high RPM and high Load; Ray tells me that one of the other wires may be bad.....and to take it easy until we see the issue. I think it may be the dwell... but am unsure.
Driving from a flat surface to an extreme uphill with BC settings at 10 PSI to redline and the same PPO2 tune I've been running for about 3-4 months.... I hear a very loud misfire followed by a catastrophic banging sound (uh-oh).... I let off the throttle and my vacuum is all over the place and I'm boosting 10 PSI to maintain 60MPH uphill..... well ****; there goes the motor. I happened to be logging at the time; which was nice.
Here is the datalog of my motor going bang.... the redline is the moment she went out. It makes more sense when you can see the whole thing - but whatever.
Now - Ray TOLD me to take it easy; and I was; but the BC should have been off and maybe I would have avoided this situation (my bad) - hard to say...... rotaries love turbo's and that bitch spools quick. But then again at that time we weren't sure that dwell was an issue.... **** happens.
I called Ray that morning; he made fun of me.... I called him fat - the norm; LOL and Erick laughed at me too I think. Turns out that weekend is when Jeff and Ray had started to see dwell issues for the big power boys on the BHR coils..... a day late for me!!!! HAHA.
Soooooooooooooooooooooooooooooooooooooooo
If you give a mouse a cookie
After talking to Ray; my choices were - new OEM motor; rebuilding mine assuming both housing were good; or super secret option number 3. This is where BHR customer service comes into play.
Ray had a motor in his shop; awaiting his experimentation.... it was blown but had low mileage; I had a dead motor in my car - and the desire to get my car rolling so I could PCS from Hawaii....... we decided on a trade; he gets mine and he rebuilds his for me n AZ and ships it to HI; flys here and helps me install it. Basically; Ray said "yeah that is cool man; I've been wanting to play with this thing anyway but just haven't had the time and parts." Now call ******' Edlebrock and try to work that deal if a bad fuel pump kills a 350.
My next phone call; was back to Ray..... "hey man; since we are building this thing anyway - how crazy can we get with this thing?" We both made a few dozen phone calls to various experts like Kevin (Rotary Resurrection), Sven (NRS Rotorsports) and Brian (BDC) among many others; and settled on.
Hand cut side seals and hand built ported motor with everything documented (courtesy of Ray); Ceramic 1 piece 2mm apex seals with FD corner seals (NRS); the rotors had to be machined to accept the taller seals and springs. Ray is also hooking it up with a BHR stage 2 Clutch.
I then did my part; first spent a lot of money then custom built air intake based of the AEM; took old motor out; flow tested and balanced all of my injectors, Mazmart water-pump, power-coated EVERYTHING; Elite Series fuel pressure gauge; refinished my sub-frame; and got a set of Prototype Motormounts from Old Dragger. On top of obviously doing the tuning; however the MAF vs injector scale issue is much easier when you have your injectors flow tested. And while the engine was out I redid all the engine bay wiring cause I could.
From Arizona!
OOPS new housing time....
And from Hawaii
Coming up live streaming video of the re-install from BHR / BBQ; live tuning from Kane and PPO2 and all in time ( I Hope) to get me out of Hawaii on Nov 13th.
Now - who wants to question BHR's customer service reputation...... hmmmmm?
Now - for the first ever hand built, ceramic sealed; GT3071R turbo-ed, ported Renesis engine to show it's stuff!!!!!!
Old Nov 3, 2009 | 11:22 PM
Kane's Avatar
So far..... BIG BIG thanks too:
Ray Hill @ BHR
Erick @ BHR
Sven @ NRS Rotorsports
Kevin @ Rotary Resurrection
Brian Cain @ BDC
Yoshi @ Ron's Performance
Bobby aka PunisherRX8
Richard aka JudgeGTO2005
Mazmart
AZRR
Old Nov 3, 2009 | 11:23 PM
dozer's Avatar
on his 3rd rx8
Old Nov 3, 2009 | 11:26 PM
RyansRx8's Avatar
Brettward is/has a G
Me likey
Old Nov 3, 2009 | 11:29 PM
gregs's Avatar
Pull My Finger
cant wait to watch the live stream kane! what kind of wiring clean up are you planning?
Old Nov 3, 2009 | 11:35 PM
Kane's Avatar
Mostly just getting all the aftermarket stuff to tie into the factory harnesses at the firewall; I was going to try to get the main harnesses below the fender wells..... but I need some serious electrical help to pull that off I think...
Old Nov 3, 2009 | 11:37 PM
gregs's Avatar
Pull My Finger
i was hoping you were planning tucking under the fender..haha
Old Nov 3, 2009 | 11:38 PM
Kane's Avatar
Once I looked at it in detail - it would require re-wiring the whole bay to do it right......... that's a lotta work.
Rotor Gunnin' it's Avatar
Can't wait to see wat this kind of set up can do.
Old Nov 3, 2009 | 11:39 PM
Nemesis8's Avatar
Bigus Rotus
You will need lots of ice cubes.
Did Ray pin the short block?
Old Nov 3, 2009 | 11:40 PM
ZumnRx8's Avatar
RX8 & RX7 owner
Old Nov 3, 2009 | 11:41 PM
Kane's Avatar
Ice Cubes?
I am aiming for 400 (ISH); on pump gas no meth @ 15-16 PSI..... we'll see how ballsy I get.
No pinning; thought about it and decided against it.
Old Nov 3, 2009 | 11:42 PM
Nemesis8's Avatar
Bigus Rotus
Ice cubes for the rum
Old Nov 3, 2009 | 11:43 PM
bout time this thread goes up, I wasn't sure how much longer I could keep the secret of this soon to be BADASS engine!
lookin' good man, can't wait for updates.
Kane's Avatar
Good call.... someone bring a bag of ice.
Old Nov 3, 2009 | 11:50 PM
remixlp's Avatar
subcribeddd!
Old Nov 3, 2009 | 11:59 PM
AWJay's Avatar
Haole
Cant wait to see this thing put in!!!
Old Nov 4, 2009 | 12:00 AM
Kane's Avatar
I get that a lot...
Old Nov 4, 2009 | 12:01 AM
Kane's Avatar
Buy me a Margarita and I'll spill all!!!!!!
Old Nov 4, 2009 | 12:07 AM
Symbioticgenius's Avatar
You Dumbass!!!
I love to see a good plan come together. Edit: When will the stream be? Date\Time\TimeZone Please Thanks.
Old Nov 4, 2009 | 12:09 AM
Kane's Avatar
Calling Flashwong!!!!
The HI part will be live I think...
Old Nov 4, 2009 | 12:15 AM
VIDEOS OF THE LIVE ACTION ... or it DIDNT HAPPEN !
Old Nov 4, 2009 | 12:31 AM
Oh damn Im definitely there for the live streaming. +1 on date/time
Old Nov 4, 2009 | 12:32 AM
AWJay's Avatar
Haole
Originally Posted by Kane
I get that a lot...
haha, its gonna be a road trip for me coming from kaneohe
editz: what beer do you like?
Old Nov 4, 2009 | 12:46 AM
Kane's Avatar
Rum and Diet!!!!!!
Veteran's Day is the BBQ
