Greddy turbo intercooler upgrade comparison test
Old Nov 3, 2009 | 02:36 AM
Brettus's Avatar
Boosted Kiwi
Spent today fitting and testing my new larger intercooler .
here is a size comparison
New intercooler installed
Flow test results :
As you can see the improvement is around 10-15g/s from 5600rpm onwards which roughly translates to 10-15whp . This is way less of an improvement than what I was expecting .
I hooked up my boost guage just after the turbo to see if the pressure drop i was previously experiencing had improved and found it had but by only about 1 psi .
Still seeing about 5psi pressure drop across the system .
My IATs at cruise dropped from about 12degrees above ambient down to about 7-8 degrees above ambient .
So : I am a little dissapointed with the result . There are a couple of possibilities for why these results were not that good :
1/ The cheap intercooler i bought just does not flow that well and is still causing a significant restriction.
2/ The 50mm dia pipeing to the intercooler is causing a restriction .
Will have to hook up the boost guage to just before the intercooler to determine that .
EDIT : swapped back to Greddy - see posts later in thread to see why .....
IC swap mk 2 (july 2011) this one a little smaller and getting similar results for flow and IAT difference (8 degrees above amb. at cruise)
Old Nov 3, 2009 | 05:58 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Interesting that I just ordered a very similar IC. I was going to go whole-hog and get a custom one, but descided at the last minute to cheap out. Where'd you get yours? Mine is a low priced godspeed specV.
Old Nov 3, 2009 | 10:06 AM
gregs's Avatar
Pull My Finger
good data brettus!
Old Nov 3, 2009 | 10:34 AM
Brettus's Avatar
Boosted Kiwi
it is probably the same one - those cheap intercoolers all look like they come from the same factory .....
Old Nov 3, 2009 | 11:05 AM
Brettus's Avatar
Boosted Kiwi
Originally Posted by gregs
good data brettus!
cheers
Old Nov 3, 2009 | 02:05 PM
Brettus's Avatar
Boosted Kiwi
Put in some results from another run done just the day before the intercooler was put in which shows a little better gain - average gain from 5500 through to 8000 was 13g/s with 15g/s average from 7000-8000 .
Still about 1/2 of what I had hoped for - may do another run today as the run with the new intercooler was a little richer than the one with the Greddy ..
Old Nov 3, 2009 | 06:48 PM
J.Cab's Avatar
1st RX8 BNR Turbo Owner..
So at how many PSI were you at when you data logged this information?
Old Nov 3, 2009 | 07:43 PM
Brettus's Avatar
Boosted Kiwi
logged at 10 psi to about 6500rpm tapering down to approx. 8psi at 8000
Old Nov 3, 2009 | 07:53 PM
J.Cab's Avatar
Alright well I am looking into a new intercooler for my car. The measurements of the core are 24*12*3.5 do you think I would be safe or should I go with something smaller?
Old Nov 3, 2009 | 08:03 PM
Brettus's Avatar
Boosted Kiwi
don't know what you mean by "safe" . I'm sure it would do the job . it will be a very tight fit though - took quite a bit of work to squeeze in my 3" one .
Kane's Avatar
Why?
Old Nov 3, 2009 | 08:07 PM
J.Cab's Avatar
Originally Posted by Kane
Why?
Because its an AGP intercooler and its only gonna cost me $25.00
Old Nov 3, 2009 | 08:10 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Dude, buy it. If it doesnt work, you could basically give it away with barely a loss. No risk there.
Kane's Avatar
I try to avoid slapping things onto my car that I don't know if I need; FWIW....
Old Nov 3, 2009 | 08:14 PM
J.Cab's Avatar
Alright although I may just do what Brettus did and install it, collect data, etc. Then decide if it would be worth it to keep it installed. I just researched the intercooler and it seems to be a really good one. So I will see what happens. Speaking of which, Kane I will go ahead and send you some datalogs here in a bit when I get back!
Old Nov 3, 2009 | 08:17 PM
Kane's Avatar
The point is; if you see a temperature and pressure issue then you can get a bigger intercooler; but since you don't know you can't really say that.
Remember bigger intake volume slower boost response....
Old Nov 3, 2009 | 08:24 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Transient boost response delay with a IC that is 50-70% will be minimal. Flow is more important anyway.
Pluses for an upgrade: Somewhat demonstrable increases in flow on a upgraded greddy (thanks to Brettys). Likely definite increases in flow with a bigger snail. Greddy ic is easy to bend and puncture, bar n plate (with quality alloy) is more resistant. Also, I removed the ugly black plastic thingy on the top of the opening on my MS bumper. With the Greddy ic, there is a big ugly gap. New ic is purdy.
Negatives?
Old Nov 3, 2009 | 08:29 PM
Race Roots's Avatar
Former Sponsor
Looking good! We actually have some intercooler brackets if you guys are interested. Should be available for the community shortly.. and for a very good price too
I have one spare to sell now.
Also Brettus it is the IC piping of the Greddy Kit that is the restriction from what you are experiencing.
Old Nov 3, 2009 | 08:30 PM
Kane's Avatar
Negatives?
Cost, Labor, Fitment, blocking larger area of the radiator; slower boost response, larger drop in airflow densities.....
Ideally; running no intercooler is the best - but we are kinda stuck needing one - so the next best thing is to run the smallest intercooler we can.
Old Nov 3, 2009 | 08:32 PM
Race Roots's Avatar
Former Sponsor
I have one similar in size and my water temps are fine..still on a stock Radiator and stock water pump.
Old Nov 3, 2009 | 08:42 PM
Brettus's Avatar
Boosted Kiwi
I just doctored the greddy brackets .
Would like to run my boost gauge to just before the IC to test the 50mm pipework but don't really want to weld a fitting in there ....
Old Nov 3, 2009 | 08:43 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Just to continue the discussion:
Cost. This guy is getting one for $25. Most can be gotten for less than $300.
Labor. Seriously? Isnt this part of the fun, putting it on?
Blocking the radiator. Biggest negative, IMO. Very important to consider.
Slower boost response. I cant find it right now, but a quick calculation suggests that this is practically minimal. And again, flow is more imporant anyway.
Larger pressure drop? Most bar and plate ics run around 0.5-1.5 psi. Not going to be much of a difference between that and stock. And again it is likely to flow better, which is more important anyway. Granted you need the compressor to give you the flow...
I am not sure that the statement "running w/o an ic is better" is generally true. In fact, given the greddy set up, running with an ic is demonstrably better. I can imagine if you had a blower that was 100% efficient, then yes, running without an ic would be better, but while running in the 65% eff range, I am going to keep mine on.
Old Nov 3, 2009 | 08:49 PM
Kane's Avatar
Keep in mind; I am not saying it WILL; simply that installing parts for the sake of installing parts is stupid; matter of fact I just turned down a Greddy oil pan because other than the second drain valve there is no REAL reason to change.... and $300 is $300.
In this case - get the IC efficiency gauge; http://www.bimmerworld.com/html/spa-...-out-gauge.htm or the like.... and if you are seeing spiking temperatures then you know it is time to change up.
There is a company that makes a temp and a pressure one; I am just too lazy to look for it right now.
If larger intercoolers were always better; why not just get a 4" thick; 3' by 4' one..........answer; because it is inefficient for our application.
Old Nov 3, 2009 | 08:50 PM
Kane's Avatar
PS - other than air temperature; there is NO good reason to run an intercooler..... it is an obstruction by definition.
Old Nov 3, 2009 | 08:54 PM
Brettus's Avatar
Boosted Kiwi
Updated the chart in the first post with one more representative of the difference . IE same ambient temps and AFR .
