RX8Store RX-8 Performance Parts and Accessories, Visit RX8Store
Tein CS Coilovers Available
Old Jan 12, 2004 | 04:40 PM
Jason's Avatar
RX7store.net
I have a couple of sets of Tein Type CS coilovers on the way. Should be here in the next 2 weeks. Price is $1399
Only 3 sets are coming to the US then they will be on backorder for a month.
Some info on the CS
TEIN Type CS damper was designed to give comfort to sophisticated drivers.
We adapted a hard rubber upper mount for noise proofing and mono-tube type shell case to heighten road holding.
* Improved ride comfort over original shock absorbers.
* A hard rubber upper mount is used for noise proofing.
* 16 levels of damping force adjustment (compression and rebound together).
* Ride height adjustable.
* A mono-tube design and increased shell case diameter allow for 30% more oil capacity,
as compared to OEM shock absorber, to handle the upsizing of wheel with lower profile tires.
* Available for overhaul.
Old Jan 12, 2004 | 04:43 PM
Jason's Avatar
RX7store.net
Picture of the CS
Old Jan 12, 2004 | 06:02 PM
HottRodder's Avatar
How about the Flex, HE or any of the 'competition' oriented models. Do you know when those will be available?
Old Jan 12, 2004 | 06:21 PM
Omicron's Avatar
Hmmm, interesting. How do these compare with the JIC?
Old Jan 12, 2004 | 08:12 PM
Jason's Avatar
RX7store.net
The Flex and the others will in Febuary sometime.
The CS are more street oriented than the JIC. Its going to give you a more comfortable ride with the height adjustability of a coilover system.
Old Jan 22, 2004 | 01:47 PM
VividRacing.com's Avatar
I find that the JIC set in the softest setting are just as comfortable as the stock set up. The other cool thing is that now all sets come with remote damping adjusters for the rear that are easy to get to throgh the trunk.
Brokegang
Jan 3, 2016 12:45 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
