Camber suggestions?
Old Oct 19, 2009 | 06:15 PM
blackenedwings's Avatar
Life begins @ 30 psi
Question Camber suggestions?
I haven't really delved into fine tuning my suspension before and I'm starting to make a few changes to my current setup. I have OEM Tokiko (Shinka) shocks with Tein S-Tech springs, Enkei RPF1 18x9.5 wheels with 165/35/18 tires. I have been doing some aggressive canyon carving recently and decided to add a bit more negative camber. I'm now running -1.5% and it seems reasonable, but I was curious what other people are running with similar setups for both track and street.
Old Oct 20, 2009 | 05:57 PM
kster's Avatar
There is an alignment sticky in the Competition forum; that would be a good place to get ideas.
Old Oct 20, 2009 | 06:32 PM
EricMeyer's Avatar
Dude, you've embarassed yourself. You have a zillion posts on this site and you're asking a generic camber question? There is total overkill info on camber. Read, read, read, read.
Old Oct 20, 2009 | 06:41 PM
TopGear8's Avatar
mkuhnracing.com
165/38/18? Man you are on some tiny tires
If your only doing aggressive driving on the street, then you dont need anything more than -1.5 degrees, not %, of camber. Currently i'm running -2.4 in the front and -2.2 in the rear. But I AutoX and do Track days frequently.
Check out this thread, it will tell ya all you need to know. https://www.rx8club.com/rx-8-racing-25/alignment-settings-street-track-use-43308/
Old Oct 20, 2009 | 06:42 PM
I'm not embarassed... I honestly don't know much about alignment settings at all and I did search several times, but I didn't think to check the competition subforum. I never go in there or post in there, so I just assumed camber settings would be in the Brakes & Suspension section. I searched in there and found a bunch of random crap that didn't answer my question... hence the new post.
Thanks kster for the thread link, I'm reading through it now.
Old Oct 20, 2009 | 06:43 PM
No amount of camber will help when running 165 width tires
Old Oct 20, 2009 | 06:44 PM
165 tire on a 9.5 wide?!
Old Oct 20, 2009 | 06:45 PM
Check out this thread, it will tell ya all you need to know. https://www.rx8club.com/showthread.php?t=43308
Lol, as you can tell I was a little pre-occupied when I posted this... um, I'm actually running 265/35/18... :P and I meant degrees not %.
I spent a good portion of the morning trying to sort out an overboosting problem, followed by some random adjustments to my suspension which was out of alignment so I decided to go for a more aggressive camber angle without really knowing what I was shooting for. Thanks for the suggestion.
Brokegang
Jan 3, 2016 12:45 PM
duworm
Oct 1, 2015 04:57 PM
titaneum_grey
Sep 16, 2015 11:51 PM
