anybody got a .csv log of an n/a with stock MAF scaling?
Old Oct 19, 2009 | 04:13 PM
arghx7's Avatar
I'm just interested in seeing MAF and load readings under WOT pulls especially. Or can anyone tell me what is the typical peak gram/second and lpeak oad reading on a stock or mostly stock n/a car?
Old Oct 19, 2009 | 05:01 PM
MazdaManiac's Avatar
As the OE MAF calibration sees it (with no add-on intake or exhaust), the MAF can range from 190 to 220 g/sec around 8000 RPM, where it typically peaks.
FYI - The highest MAF reading I've seen so far (on a turbo car) was 454 g/sec. The lowest peak MAF reading I've seen on a totally stock car (a 2004 that probably had a "soft" engine) was 176 g/sec.
Old Oct 19, 2009 | 05:04 PM
blackenedwings's Avatar
Life begins @ 30 psi
Jeff... please call me.
Old Oct 19, 2009 | 05:23 PM
All over the map right now.
If you need me, please use e-mail only. Thanks.
Old Oct 20, 2009 | 07:50 PM
arghx7's Avatar
190 - 220 g/sec... what absolute load rating are you measuring at that peak rpm and airflow ?
Old Oct 20, 2009 | 07:59 PM
myriadshalaks's Avatar
rot8ing
best i can do -- intake and exhaust only
Attached Thumbnails anybody got a .csv log of an n/a with stock MAF scaling?-stock-3rd-wot3.jpg
Old Dec 6, 2009 | 10:31 PM
arghx7's Avatar
so I was tuning a friend's Subaru Legacy GT today using AccessTuner. Those are basically STi's with smaller turbos, so 2.5 liter 4 cylinder boxer engine.
Interestingly enough, his peak MAF values (stock MAF stock intake stock turbo) were slightly lower than your log there ^ and he was running peak boost of 16psi tapering down to about 12 as the turbo ran out of breath. That's with a full 3 inch exhaust, stock turbo, catless uppipe. The car was on a dyno that is not known to read high (Land & Sea Dynomite) and it did 220rwhp/260rwhp torque. With less airflow than a stock Rx-8. It peaked at about 220 g/sec around 4000-4500rpm and held flat up to about 6500 rpm as the boost tapered off.
I'm not sure what's more impressive, how much air a rotary can flow or how little power it can make with that flow? I really hope Mazda makes some big strides with the new combustion chamber design, this is kind of ridiculous.
Old Dec 7, 2009 | 12:13 AM
Maybe your expectations and understandings are ridiculous?
Old Dec 7, 2009 | 10:04 AM
Rotary motors have a lower BSFC and the torque lever arm is significantly lower.
Its just the design.
Old Mar 20, 2010 | 05:11 AM
recently heard of a stock port NA Renesis engine pulling 290 g/sec peak
Old Mar 20, 2010 | 07:58 AM
The Grand Am cars were almost that high.
That's a lot of air - 240 RWHP worth.
Old Mar 20, 2010 | 10:04 AM
ive been told of 260hp engine dynos by a team or 2 last year. but this would be more like 270-275 yeah? not on straight gas?
Old Mar 20, 2010 | 11:47 AM
Nemesis8's Avatar
Bigus Rotus
stock port? like in unmodified?
Old Mar 20, 2010 | 01:47 PM
Not Stock
Hears a non - stock
Attached Thumbnails anybody got a .csv log of an n/a with stock MAF scaling?-razzmafchart.jpg
Old Mar 20, 2010 | 09:07 PM
Yes factory stock unmodified at sea level
VP100 unleaded gasoline
Old Mar 20, 2010 | 11:04 PM
Here is a log I took tonight from Grungepups stock 8.
Higher RPM's but not red line (obviously)
Old Mar 20, 2010 | 11:16 PM
Here's a lightly modified 2005 RX-8 with a healthy motor.
WOT.CSV
Old Mar 21, 2010 | 09:46 PM
WOT.CSV
Meh, no CSV iPhone app .......
Old Mar 22, 2010 | 08:29 AM
JinDesu's Avatar
went back to srsly broke
WOT.CSV
I like that 240 up there at 100% load.
Old Mar 22, 2010 | 02:19 PM
For those of us at higher elevations I assume the same 4% power loss per 1000 feet also applies equally to the MAF rate?
Old Mar 22, 2010 | 03:22 PM
I never really sat down and did the math for this, but that seems logical to me.
Old Mar 22, 2010 | 05:56 PM
In that case, wow ....
Old Mar 22, 2010 | 06:20 PM
Brettus's Avatar
Boosted Kiwi
256g/s ..........
wow
Brettus
46
Apr 19, 2024 06:28 AM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Zube6115
Sep 30, 2015 12:57 PM
DVerdeyen
Sep 13, 2015 11:19 AM
