CAI and tune
Old Oct 14, 2009 | 05:44 PM
MFslacker22's Avatar
CAI and tune
Im currently running the Greddy turbo kit intake (which we all know isn't the best). I'm just wondering how much it will mess up my tune if I decide to route a CAI under the front bumper. Currently my intake temps are over 100 degrees and after adding the CAI i assume they will drop 30-50 degrees depending on the temperature outside.
also, I read somewhere that the piping for the intake needs to be 3.5 inches for the accessport to work properly. Why wont 3 inch piping work?
thanks
Old Oct 14, 2009 | 07:48 PM
shinka911's Avatar
subscribed
Old Oct 14, 2009 | 07:56 PM
EMart11b's Avatar
Bang Bang
You need tubing the same size as stock for the MAF to get correct readings.
Old Oct 14, 2009 | 08:01 PM
oh that would make sense. I never measured the stock one just assumed it was 3 inches.
Old Oct 14, 2009 | 08:09 PM
NgoRX8's Avatar
the maf position of the greddy is so messed up because of the short distance between the intake and the sensor. it also doesn't help that the tube size practically steps down right away after the maf. turbulence is a huge problem.
anytime you change the maf, you'll need to adjust your tune.
what works is a 3 3/8" ID (which means 3.5" OD), which is the same as stock. going with a 3" pipe will lower the max amount of air going in the engine, according to the MAF. That is because the maf voltage will max out sooner at 5V .
tbiggybig
35
Jul 14, 2022 06:14 PM
Hunterkelley24
Jun 14, 2022 08:32 AM
Danield97
Sep 30, 2015 05:59 PM
Zube6115
Sep 30, 2015 12:57 PM
