Stripped Spark Plug - Any suggestions???
Old Oct 11, 2009 | 10:42 AM
tntmst's Avatar
Angry Stripped Spark Plug - Any suggestions???
Ok so the back rotor, trailing spark plug was a pain to get out , when I finally got it out, I saw why....
So now I need some suggestions on how to fix spark plug hole so I can put in the new spark plug.
Read this thread, and I'm thinking of trying it out....
https://www.rx8club.com/showthread.p...oil+spark+plug
Would like to know if anyone has some different suggestions??????
Old Oct 11, 2009 | 10:44 AM
tntmst's Avatar
Looking for a way to fix by hand, without power tools if at all possible.
Old Oct 11, 2009 | 10:45 AM
bumblebeerx8's Avatar
Rear Mount GT35R
the only thing i can suggest it chasing it with a tap i had to do mine on my explorer because the one is a pain and alot of people leave it in. once they do take it out this happens, or anti seize was never used
Rear Mount GT35R
yep use a tap and crank it in with a cresent wrench
alnielsen's Avatar
Heli-Coil - http://www.emhart.com/products/helicoil.asp
You may want a mechanic experienced in installing one to do it.
Old Oct 11, 2009 | 10:47 AM
Rear Mount GT35R
fastenal or some hardware stores will have them im sure if you take one of the plugs with you good threads of corse you can match it up with a nut to find out what thread and corseness you will need
Old Oct 11, 2009 | 10:49 AM
Rear Mount GT35R
that may work too but wont the hole have to be drilled oversized to accomidate the width of the stainless coil
Old Oct 11, 2009 | 10:53 AM
alnielsen's Avatar
Yes, but if you look at the threads of the plug, a lot of the holes thread material is gone. I fear tapping out the hole won't be successful.
I've never used the product. There may be a better way. I just know helicoils have been used for stripped plug holes.
Old Oct 11, 2009 | 11:02 AM
Rear Mount GT35R
its questionable not knowing how much is there if its less that half tapping would be questionable if not impossible. and if you have to sleeve deffenty take it somewhere to have done by someone that has done it and takes care of a mess up that could save you in the long run
Old Oct 11, 2009 | 11:10 AM
tntmst's Avatar
The new spark plug will not even go in far enough to stay in.
of course everyone around here is closed on sundays so i will have some calling to do first thing in the morning.
I,m headed up to ACE to check out the kit that they have and see if it will be worth a try.
Old Oct 11, 2009 | 11:58 AM
Rear Mount GT35R
good luck^ i pulled my plugs out yesterday and prayed this would not happen not knowing who did it before me
Threshermal
Apr 15, 2020 09:43 PM
uZu
Dec 30, 2015 12:35 PM
TeslaMSI
Dec 10, 2015 01:10 AM
TJSiegrist
Sep 10, 2015 09:29 AM
Psychofox
Aug 20, 2015 04:48 AM
