AFR Gauge
Old Jan 9, 2004 | 08:34 PM
epitrochoid's Avatar
Riot Controller
AFR Gauge
Is there any way to install an air/fuel ratio gauge in an 8 in a way that it's actually useful? Not for tuning, but just to keep an eye on. The autometer one, the only one ive seen hooked up, is worthless, those LED's are all over the place.
I heard analog ones are better. ANy suggestions aside from a wideband (which is an option BTW)
Old Jan 10, 2004 | 02:05 PM
kristopher_d's Avatar
Drive Master
You should be able to pull that info out of the ecu. There's a factory Wide-Band ahead of the Cat.
Drive Master
cliffkemp
Dec 24, 2024 10:48 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
JantzenRX-8
Oct 4, 2015 11:30 PM
