HELP: AFR too lean
Old Sep 9, 2009 | 10:06 PM
rx8dorifto's Avatar
HELP: AFR too lean
Tried logging the data from O2S1 using OBDKey Bluetooth and here is what I got:
~mA~~~ EQ Ratio~~RPM
-0.121~~0.970~~~~1042
-0.027~~0.993~~~~1099
-0.238~~0.945~~~~1140
-0.215~~0.949~~~~1200
-0.051~~0.986~~~~1214
0.227~~1.097~~~~1241
0.113~~1.041~~~~1267
-0.188~~0.955~~~~1390
-0.102~~0.974~~~~1764
-0.098~~0.976~~~~2232
-0.152~~0.962~~~~2750
-0.414~~0.908~~~~3320
-0.727~~0.852~~~~3886
-0.316~~0.928~~~~4500
-0.504~~0.890~~~~5085
-0.363~~0.918~~~~5727
-0.512~~0.889~~~~6359
-0.535~~0.885~~~~6967
-0.820~~0.836~~~~7549
-0.543~~0.884~~~~8031
-0.418~~0.907~~~~8594
0.555~~~1.256~~~~8822
According to:
To convert EQ Ratio to AFR, use: AFR = {stoich}/EQ
To convert Lambda to AFR, use: AFR = Labmda/{stoich}
To convert AFR to EQ Ratio, use: EQ Ratio = {stoich}/AFR
To convert Lambda to EQ Ratio, use: EQ Ratio = 1/Lambda
To convert EQ Ratio to Lambda, use: Lambda = 1/EQ Ratio
I assume that the Stoich for RON97 petrol is 14.1 and apply "14.1/EQ Ratio". Is this equal to {14.1}/EQ Ratio? not sure what is the curly bracket means.
And my AFR looks way too lean.
Attached Thumbnails HELP: AFR too lean-afr_14.1stoich.jpg
Old Sep 9, 2009 | 10:42 PM
#'s below Lamba 1.00 are rich.....
Stoich is closer to 14.7 AFR
Old Sep 10, 2009 | 12:54 AM
rx8dorifto's Avatar
If I used divide the EQ Ratio by 14.7 stoich, it's even leaner...
Maybe the reading of OBDKey from stock O2S1 is Lambda instead of EQ Ratio. Then it makes sense.
The 1st graph in my previous post was calculated with {Stoich}/EQ Ratio, which is 14.1/EQ Ratio.
The 2nd graph here is assuming that the reading from OBDKey of O2S1 is Lambda and calculated with Lambda*14.7. This is assuming that the data is in Lambda, and the AFR looks correct.
Attached Thumbnails HELP: AFR too lean-afr.jpg
Old Sep 10, 2009 | 11:37 AM
OEM programming or are you running a custom map?
Old Sep 10, 2009 | 12:16 PM
NgoRX8's Avatar
it is in lambda. you're afr's look more or less normal depending on load.
Old Sep 10, 2009 | 07:50 PM
rx8dorifto's Avatar
Knight Sports reflash
Old Sep 11, 2009 | 06:11 AM
rx8dorifto's Avatar
So, the stock O2S1 read in Lambda? Thought it only read in mA and the OBDKey software did the conversion...
04Green
12
May 13, 2023 10:08 PM
fistofmeat
Oct 7, 2016 12:15 PM
JantzenRX-8
Oct 4, 2015 11:30 PM
dbarber
Jul 25, 2015 01:34 PM
