Front splash guard installation - what cutter to use on stone guard?
Old Sep 2, 2009 | 11:53 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
I am thinking of putting on the front splash guards. I found the helpful thread below. Installation seems straightforward, but one needs to cut the stoneguard on 8's with 18" rims.
It says to use an ultrasonic cutter or similar device. Any suggestions on what to use other than an ultrasonic cutter?
https://www.rx8club.com/showthread.p...d+installation
Old Sep 3, 2009 | 12:39 AM
lopezian2004's Avatar
Master Shr3dd3r
I just went out to home depot and bought me a generic all purpose cutter. The stone guard material isn't really a tough material, you'll feel it when you get it detached from the car.. just needs a tad bit of strength to get the cutters to actually cut through the guard.
Old Sep 4, 2009 | 10:11 AM
cornholio135's Avatar
SARX
When I did my rear flares I usd a jig saw to cut it...
Old Sep 4, 2009 | 11:08 AM
pdxhak's Avatar
Official Post Whore
I used a Dremel to cut the stone guard. If you are careful and have steady hands then you can make the cuts without removing the stone guard.
Old Sep 4, 2009 | 11:11 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
If I remember correctly.....and I probably don't, I think I just used a pair of tin snips and I don't think I took them off either. If you are carefully and don't use something too bulky to do the cutting, then you can do it with them on.
Old Sep 4, 2009 | 11:57 AM
416to212's Avatar
Utopia Taco Bell
I used an exacto knife and some side cutters. The stone guard stuff is not tough, you really don't need any special cutting tools.
Old Sep 4, 2009 | 12:01 PM
pdxhak's Avatar
Official Post Whore
It is somewhat soft but a cutting tool would be way easier. Especially if you cut while it is attached to the car.
Old Sep 4, 2009 | 05:02 PM
nuke0907's Avatar
Never Blend In
i just took mine off and left them off. they dont even come on all trim levels anyways.
Old Oct 18, 2009 | 12:25 AM
dntsan's Avatar
So you dont really have to have the stoneguard in order to install the front splash guards? I want to get one but I don't really want to cut into my rx8.
Old Oct 24, 2009 | 01:36 PM
smokedRX8's Avatar
9k Redline
you just have to cut it so the base mounting point of the actual splash guard is in contact with the bottom of the car. The stoneguard, if i remember right, it's been a while, is just a long piece of rubber. use an exacto knife. not really cutting into the car...
Mr. Pockets
RX-8 Racing
19
Oct 17, 2019 08:03 AM
RXeckless
Aug 16, 2015 12:51 PM
akagc
Aug 11, 2015 07:07 PM
AussieGray
Jul 16, 2015 03:58 AM
