Engine Oil (Recommended in Australia/New Zealand)
Old Jul 17, 2009 | 01:44 AM
atruerx8racer's Avatar
AJ- THE True Rotarian.
What engine oil does Mazda recommend Rotary owners in Australia/New Zealand? to add.
Old Jul 17, 2009 | 01:53 AM
Revolver's Avatar
Shootin' from the hip
Mazda Rotary Oil
Old Jul 17, 2009 | 02:23 AM
Brettus's Avatar
Boosted Kiwi
Mazda rotary oil - 5w30 dino
Old Jul 17, 2009 | 03:03 AM
auzoom's Avatar
Hmmmmmm.........
Can I ask why this thread has been started in each reagional sub forum?
Old Jul 17, 2009 | 03:08 AM
Brettus's Avatar
Boosted Kiwi
he is on some kind of crusade
Old Jul 17, 2009 | 06:34 AM
auzoom's Avatar
Hmmmmmm.........
And we all know what happened at the end of the crusades!
Old Jul 17, 2009 | 12:11 PM
Trying to find out if the article that I've read is true about rest of the world using 5-30 engine oil and in the U.S rotary owners using 5-20. Did you read the link I've posted? Read the article.
Old Jul 18, 2009 | 01:00 AM
auzoom's Avatar
Hmmmmmm.........
No, I haven't read the article because I am not going to go and read 500 threads you have created to find which one its in. You didnt state that in your first post.
If you had read the many threads on this topic here you would understand that in the US they recommend more than just 5W-20, its specific to the climate. Have a look at your manual.
Andrew
Old Sep 2, 2009 | 10:58 PM
ASH8's Avatar
Super Moderator
As Andrew said, look in your Owners Manual....
If it is an Australian One, the Japanese (Mazda) printed book shows virtually ALL Viscosity ranges CAN be Used...depending on "your" climate.
Anything from a 0W50, W50, 5W20, 5W30, 10W40, 15W40, 20W50, and so on.
Mazda Rotary Oil is supplied and Made by Castrol Australia and is a 5W30 (mineral combo).. and is very pricey at Mazda Dealers.
In Summer I use CASTROL GTX 3, 15W40 ALL mineral , and is the suggested oil by Castrol's website for the last REW Turbo RX-7.
The 5W20 oils recommended in the USA have shown to be inadequate by private Rotary Re-builders who have been re-building all Rotary Engines including the RX-8.
Excessive stationary gear Bearing Wear is the main problem, which in turn will create other problems in eccentric shaft alignment, which in turn can cause severe wearing on Apex and Corner seals, it is a snowball of problems, you DON'T want any bearings to wear.
Most re-builders are recommending a higher viscosity oil of 5W30 or even 20W50 for high mileage cars.
You have to remember that Viscosity in rotary engines tend to head south very quickly after a few thousand kilometres, it can also becomes diluted from fuel.
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
akagc
Aug 11, 2015 07:07 PM
RotaryRider
Jul 20, 2015 07:05 AM
