Help Please - Car won't start.
Old Jul 6, 2009 | 03:48 AM
Brettus's Avatar
Boosted Kiwi
Flooded - read this
https://www.rx8club.com/series-i-trouble-shooting-95/how-start-your-car-when-wont-start-174376/
Old Jul 6, 2009 | 03:54 AM
rotarenvy's Avatar
it's probably flooded. depending on how long you have cranked it the spark plugs are probably fowled.
try removing the injector fuse and cranking the car with the throttle depressed. it may want to start after a few try's cranking. if it doesn't replace the spark plugs and repeat until it wants to start. then replace the injector fuse and it should start.
Old Jul 6, 2009 | 05:51 AM
rotarykillz's Avatar
Rotary Freak
Post #5 here did the trick for me after everything else failed. It did foul up my spark plugs pretty bad but they ran for another 3 or 4 weeks until I received the rest of my tune up stuff.
https://www.rx8club.com/showthread.p...ighlight=flood
Old Jul 7, 2009 | 06:42 PM
Spinning Sushi's Avatar
I <3 Sushi
The method that ALWAYS seem to work for me on countless rotary is to push start and clutch pop it. I've done it in a bunch of 7's and three 8's. It worked every time.
It's a two step process really, make sure your ignition is off, push it to about 8mph and then put it into first gear and pop the clutch. This will get all the extra gasoline out of the engine.
The second step is to either try to start it by cranking or push start it with the ignition in the on position. I prefer push starting it just in case I didn't get all the gas out. Like I said, this worked every single time for me.
Old Jul 7, 2009 | 07:01 PM
Brettus's Avatar
Boosted Kiwi
/\ me too except i've never done stage one of your process
Old Jul 10, 2009 | 07:19 AM
takahashi's Avatar
Originally Posted by GeoffRX8
oh **** me i just remembered something i did............
The plumber needed to through the garage so i moved the car out and moved it back in..i think thats what flooded it.
Glad that you fixed it now, but I don't think it is just that you move it and flood it.
There are combination of things. Weak battery, trying to start a engine that is partly flooded, with old coil, old plug and old spark plug line. I guess if you had rev it to 3500 rpm for 10 sec before shut down - it may not had happen.
The 60000km plug change is NEVER a good idea. I am on my 4th plug and they are clean at least twice. I just tick over 60000km since 2003.
Now the car is permanantly on triggle charger. But I have no doubt I can start it within a sec everytime.
Enjoy zoom zooming and look after the babe from now on.
Old Jul 10, 2009 | 12:49 PM
Brettus's Avatar
Boosted Kiwi
This is so true .
After 41/2 years of ownerships and numerous atempts to flood the engine I still have not managed to do it - and I still have the old slow starter .....
Old Jul 10, 2009 | 09:53 PM
Originally Posted by Brettus
This is so true .
yep,
i dont know how they do it..
my motor has lower compression.. a likely slightly clogged primary injector. the old starter, and a crash test fuel pump.. 110 k miles..
still.
i treat is like any other car. and it always starts.. a little slower now, but it does.
i start it and back it out of the garage and shut it down. no big deal..
my roomate does the same thing to my car..
would love to know how to mess it up..
Old Jul 10, 2009 | 10:45 PM
Brettus's Avatar
Boosted Kiwi
maybe there should be a thread on "how to flood your 8" just so we can work out how to do it ?
Old Jul 10, 2009 | 11:20 PM
and videos..
maybe it is a young thing.. we will never get it!
Old Jul 13, 2009 | 02:57 AM
Try pumping the accelerator numerous times to get gas into the engine, while the cars shut off. Maybe that will work. =p
really,
that does not work..
the ecu is that smart..
Wantingtoknow
Dec 15, 2016 02:25 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
