Transmission rebuild
Old Jun 25, 2009 | 11:59 AM
Rx8_rotory_Noobie's Avatar
RotorHeads Unite!
Cool Transmission rebuild
Wondering where online i can find a transmission rebuild kit for my car. Anyone?
Old Jun 25, 2009 | 12:11 PM
I8U's Avatar
I8U
Don't know of any rebuild kits out. Try getting all the parts through Mazda or even try MazMart.
Old Jun 25, 2009 | 05:21 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah I dont' think there are any kit will just have to call mazda and order everything you need!
Old Jun 25, 2009 | 05:26 PM
bse50's Avatar
#50
Rebuilding transmissions is not that easy too, be prepared for a hard job!
What do you exactly need? it is not an engine where you can be safe buying what you call a rebuild kit, you should have an idea of what is broken and what you might need as an extra.
Old Jun 25, 2009 | 05:30 PM
04RX8man's Avatar
^it's easy if you have done it enough times!!!! haha
Old Jun 25, 2009 | 06:56 PM
RotorHeads Unite!
I need the synchro for 1st and reverse.
Old Jun 26, 2009 | 09:30 AM
you will need much more than that to do it right and the parts aren't inexpensive even through discounted source, if you have to go to a dealer then you might as well forget it
once you figure parts and labor it will be much cheaper to buy a used one or a new one through Mazda Motorsports
this particular trans requires some special factory tools to rebuild, a very experienced shop might get by without them but one in particular is important
there is a stand-alone Mazda service manual for the RX-8 transmission
Old Jun 26, 2009 | 11:20 AM
^^yep.
Even with MMS discounts. the price of each gear is going to kill you.
It might be better for you to just buy a new or rebuild tranny from somewhere.
Old Jun 26, 2009 | 11:27 AM
RotorHeads Unite!
where can i get a cheap rebuilt tranny? found a used one on ebay with 23k miles for 600 =[ can you get one cheaper than that? would it be cheaper to go somewhere and have them rebuild it?
Old Jun 29, 2009 | 07:47 PM
the labor alone cost me $700
Old Jun 29, 2009 | 08:37 PM
You do know how much does our tranny cost brand new right ?
I wouldn't trust a 600 bux "rebuild" tranny from "ebay".
Old Jun 29, 2009 | 10:38 PM
RotorHeads Unite!
how much?
Old Jun 30, 2009 | 10:24 PM
cajunrx8's Avatar
Rotary Crawfish
Hey Team, what is the special tool you mentioned. Can it be constructed, or has to be purchased???
Old Jun 30, 2009 | 10:36 PM
04RX8man's Avatar
saw that tranny on ebay not rebuild just "used"
Old Jun 30, 2009 | 10:43 PM
I8U's Avatar
I8U
how much?
$4k plus freight.
Old Jun 30, 2009 | 11:29 PM
Its SST from Mazda.
ITs not cheap ...
Old Jul 1, 2009 | 03:12 AM
the local drivetrain shop was able to get it without the SST tools, but these guys know their poop and it took several tries before they let me have it back
Old Jul 1, 2009 | 08:42 AM
RotorHeads Unite!
not rebuilt, used. lol
Old Jul 3, 2009 | 10:11 AM
outinnowhere3193's Avatar
outinnowhere3193
Well I'm in the market to redo my tranny...and I have a guy you makes does cnc machining for a living..been there like 30 years... He builds me parts all the time. Once I get mine apart and find out what's wrong and what's going on...I might talk to him about remaking these parts...price would definably be a lot cheaper. But first I have to tear mine apart.
Old Jul 5, 2009 | 06:06 PM
cajunrx8's Avatar
Rotary Crawfish
OK what the ------ is SST? A shart holder, special wrench to remove locknuts on the gear clusters????
Never heard of it, guess a trip to the dealer is in order.
Old Jul 6, 2009 | 02:01 AM
Special Service Tool, and the last place you want to go is the dealership for them, if you really want to learn more order the RX-8 Manual Transmission Service Manual, it shows all the tools and their part numbers, most you can get by with using the usual aftermarket tools like gear/bearing pullers, etc.
http://cgi.ebay.com/ebaymotors/2004-...sQ5fLiterature
Old Jul 6, 2009 | 06:13 PM
cajunrx8's Avatar
Rotary Crawfish
Thanks Team, that is what I needed.
Old Sep 11, 2009 | 04:22 PM
newuser's Avatar
So has anyone had to do any work on their transmission in regards to Synchro's?
Ive been having alot of trouble with my reverse gear lately.. Sometimes takes about 2-3 tries before i can get it in there all the way
Old Sep 12, 2009 | 05:56 AM
outinnowhere3193
Alright guys...like I said earlier I have a guy who can make the parts..but when I looked into it I said screw it lol. Like they was saying parts are ridiculously high.
I broke teeth on the 2nd gear counter shaft...cost from mazda was like 582 and the guy said that was the best he could do...
Syncs for second was 175
first was 225
After that I stopped asking questions...
To rebuild this tranny right your going to look at a easy 1500-2000 in just the sync's and second gear...
Note second gear is known for breaking and mazda has a new part number...just cause your's is good doesn't mean it isn't going to break soon...
I was driving and everything was fine..no getting on it...no hard shifts at the time and went to come outta gear..and it was stuck in gear... Never got it outta 6th...never had any grinds except for second but that was only high rpm's...near redline.
I went with the RX7 5 speed tranny..got one from the junk yard.
As far as taking it apart and putting it back together.. you start at the tail and work your way forward and hope non of it falls apart while you take it apart...other wise it isn't that hard if your have a awesome memory and are good at doing puzzles.
Old Sep 16, 2009 | 01:51 PM
corners's Avatar
An RX ate my baby
I just had mine rebuilt with 35k on it. 2nd gear synchro went, all of the sudden. All gears were notchy when it went, and I had a lot of trouble getting it into reverse even from the day I drove it off the lot brand new. Now its smooth. They had to replace a bearing on the countershaft as well. I'm switching to better oil this weekend, its still a bit stiff when cold. I had the oil changed at 10k miles and I've been driving stick for 15 years and never had a transmission fail.
