Custom yukon(d585) coil install.....
Old Jun 22, 2009 | 03:21 PM
chancejat's Avatar
Drive it like u stole it!
Cool Custom yukon(d585) coil install.....
hey guys just thought i would show you my coils project. all together it took me 4 hours.
2.5 to fabricate the Yukon brackets
1.5 to install
i started by getting an old oem bracket and some aluminum.
cut the aluminum into bendable strips and bent them to hold the coils about 3/4 an inch off the oem bracket. i then test fitted the coils on the oem bracket and they fit beautifully so i drilled/riveted the aluminum brackets to the oem one and bolted them in. could be a little cleaner but overall they look decent.
install was a snap.
all together i spent 300 dollars on everything.
heres the pics.
Old Jun 22, 2009 | 03:34 PM
04RX8man's Avatar
Rotary Powered Countryboy
now the real ? is how are the results in the butt dyno?
Old Jun 22, 2009 | 03:37 PM
chancejat's Avatar
my butt dyno says now i dont have to spend 120 dollars a year replacing worn oem coils.....
Old Jun 22, 2009 | 04:26 PM
czar's Avatar
Almost boosted
lol, i couldnt tell when i had mine on either, looks good
Old Jun 23, 2009 | 05:53 PM
SpIcEz's Avatar
You didint mention anything about making the wirring.
How long did it take and what did you use to make the connectors?
Old Jun 23, 2009 | 06:29 PM
MazdaManiac's Avatar
Looks kinda familiar! lol
Good job.
What did you do for the harness?
Old Jun 23, 2009 | 06:49 PM
chancejat's Avatar
me and charles worked something out for the harness.....i was gonna make one but didnt know what the 4th wire was for....i guess its just a ground....but either way charles' option was easier overall. he also made the plug wires for me. the harness and sp wires cost more than the coils, lol....but money saved is money earned. right? i saved about $200 making the bracket and buying my own coils. but bhr's set is much nicer, stronger, and eaiser to install.
Old Jun 23, 2009 | 06:51 PM
chancejat's Avatar
you could make your own harnes just buy a 40 ebay harness and splice them in, then add a ground to each coil.
Old Jun 23, 2009 | 07:33 PM
Im_DANomite's Avatar
I love GOOOLD
i had this chat with Ray as well. $300 for you to install with about 4 hours is great! but for me, the extra $200 for the BHR setup is worth it. but i'm glad everything worked out for you man, looks very very good!!
so no noticeable performance increase???
Old Jun 23, 2009 | 10:13 PM
chancejat's Avatar
not until i can adjust the dwell.
Brokegang
Jan 3, 2016 12:45 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
