Broken stud on the housing
Old Jun 18, 2009 | 05:08 PM
Psychofox's Avatar
我愛台妹,台妹愛我
I was changing my water pump and while installing it , I over torqued the nut and broke one of the studs on the housing.
I cant seem to get the broken stud off so i am wondering if there is no leaking from the water pump , can i just leave the broken stud there?
Old Jun 18, 2009 | 05:12 PM
No, remove the stud and replace it, no big deal.
Old Jun 18, 2009 | 05:50 PM
Psychofox's Avatar
我愛台妹,台妹愛我
what kind of tool do i need to get it off?
Old Jun 18, 2009 | 06:14 PM
Vicegrips?
04RX8man's Avatar
Rotary Powered Countryboy
It should slide out the back right? tap with a hammer and should b able to grab it on the backside of the motor....I think...
Old Jun 18, 2009 | 06:16 PM
Good luck getting at the back of that
Old Jun 18, 2009 | 06:36 PM
04RX8man's Avatar
^haha real nobody said it woule b easy just possible
Psychofox's Avatar
我愛台妹,台妹愛我
all i have right now is a plier
gonna buy a vicegrip and see if i can get it off.
Old Jun 18, 2009 | 06:52 PM
it doesn't get interesting until it breaks off again ....
Old Jun 18, 2009 | 07:59 PM
Psychofox's Avatar
我愛台妹,台妹愛我
Yes, vicegrip did the trick
Old Jun 18, 2009 | 08:06 PM
glad it worked out
Old Jun 18, 2009 | 10:36 PM
Old Jun 18, 2009 | 11:23 PM
04RX8man's Avatar
oh ok I thought it was a differnet stud...glad it worked out for u!
Old Jun 19, 2009 | 03:18 AM
ASH8's Avatar
Super Moderator
Mazda Part Number for stud..
9985-10-826A...About $2.00
Old May 23, 2014 | 09:17 PM
jon15805's Avatar
Pretty old thread but does someone know the torque value for the stud?
Posted From RX8Club.com Android App
Old May 23, 2014 | 09:52 PM
after fixing so many cars, I sorta developed the "feel" for the right torque spec, and adjust the distance of my hand on the ratchet accordingly.
and I will use Torque wrench only when it's something more important like engine build.
oh the proper spec is 13.8-18.8 ft lbs, that's for brand new bolts btw, so if u are re-using it(most likely), I would say 15 lbs is more than enough.
Old May 24, 2014 | 06:49 AM
you get an attaboy for searching
jamespond24
Dec 1, 2015 11:11 PM
nferguson88
Oct 6, 2015 12:45 PM
ShellDude
Oct 1, 2015 09:55 PM
pjwermuth
Sep 28, 2015 11:36 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
