Help!!!! Lost Key problem
Old Jun 16, 2009 | 08:59 PM
dbdbdb's Avatar
Angry Help!!!! Lost Key problem
Hey - What's up Guys\Gals
Model - 2007 RX-8 Grand Tour
Here's my problem: I normally carry my spare key in my wallet and keep the keyless entry on my key ring.
Last week I lost my wallet with my spare key still in it {Along with all my ID's etc..} That means that whomever finds\found my wallet knows my address and the type of car I own .....
How do I change all my locks so that the lost key doesn't work ?????
I started having immediate nightmares about someone walking up and using that lost key to drive off with my car. I'm currently using a CLUB ... But I would like to have a permanent solution.
My Thanks...
Old Jun 16, 2009 | 09:04 PM
Easy_E1's Avatar
I think the only option is to have a new key programed into it. I'm not sure if they can change the code on the key you have. Or you need new key. Either way the car is going to have to be reprogrammed with a new code. And I hope you have some ID now or you know the dealer very well.
Old Jun 16, 2009 | 09:08 PM
Jon316G's Avatar
Grasshopper
At least with a new key programmed they can't steal the car.
Far as them using the key to gain access into the car, I BELIEVE if you set the alarm and try to unlock/open the door with a key (instead of unlocking it with the transmitter), the alarm will go off.
Now don't quote me on that, but I thought that happened to me once.
Wouldn't stop them from gaining access, but at least the loud horn alarming might scare them off.
Old Jun 16, 2009 | 09:16 PM
dbdbdb's Avatar
Thanks for the info ... but are we both talking about the same hardware key.
I was thinking that they would have to change out the locks or at least alter the tumblers.
To be clear ... in case of confusion {I lost my actual key NOT the electronic one}
I should add - Excuse my ignorance on this topic.
Old Jun 16, 2009 | 09:55 PM
Easy_E1's Avatar
You have the card transmitter right? That was what I was referring to.
Old Jun 16, 2009 | 09:59 PM
philipchan's Avatar
Just go back to your dealership, they will reprogram for you
is gonna be around 90~100 dollars, without key tho, just programing
if you need new keys, buy on e Bay
Old Jun 17, 2009 | 04:00 AM
dbdbdb's Avatar
Thanks Guys
Luckily the guys at the dealership know me, so that won't be a problem.
Old Jun 17, 2009 | 10:38 AM
04RX8man's Avatar
Rotary Powered Countryboy
yeah u gotta get it reprogrammed!
Old Jun 17, 2009 | 11:10 PM
dbdbdb's Avatar
I tried that today locked the car and activated the alarm with the keyless remote then, I tried using the key to open the door and the alarm didn't go off.
So with the spare key they will still be able to gain access ... this sucks
Thanks for all the help Guys.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
Emmanyei
Sep 4, 2015 11:38 PM
