no clutch pressure
Old Jun 13, 2009 | 07:23 AM
sidebar's Avatar
no clutch pressure
have this horable smell that I am burning the clutch out. Had it relaced and it changes great but there is no pressure on the clutch. It go flat to the bottom. Help!
Old Jun 13, 2009 | 08:12 AM
expo1's Avatar
He's as bad as Can
Well I would guess it has something to do with the install of your new clutch. About the only thing you can check in your driveway is maybe the clutch wasn't bled. Similar to brakes you back off the bleed screw on the clutch cylinder, pump the pedal a few times and tighten the screw back. A search for " bleeding clutch" will fine some treads about it. If that is not it you will need to see a mechanic.
Old Jun 13, 2009 | 08:15 AM
sidebar's Avatar
thanks, that will give me a direction to go in.
cliffkemp
Dec 24, 2024 10:48 AM
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
