airbag light
Old Jun 12, 2009 | 05:20 AM
rx8james89's Avatar
silver rx8
Smile airbag light
I was driving my rx8 at speed the other day an the airbag light came in the middle of the rev counter, I tried putting it on the computer to reset the Ecu but still no luck is there any way to reset the error as I don't really want to take it to mazda and get charged £80 an hour.
Old Jun 12, 2009 | 12:52 PM
Stenobeth's Avatar
a whole new world of fun
I was at the dealer today to ask about my light -- which is on because I swapped out my cloth seats for leather -- and they said disconnecting the battery and reconnecting will reset it. It didn't work for mine but that's because of the seat swap (I need resequencing or something) but if you're just looking to reset, that may be all you have to do. Worth a shot, easy to try! Good luck
Old Jun 12, 2009 | 01:16 PM
rx8james89's Avatar
silver rx8
I've tried disconnecting it still no joy its not as bad when I'm on my own but when someone sits in the passengers side it stays on constantly think I'm gonna have to take it to mazda.
Old Jun 12, 2009 | 01:38 PM
expo1's Avatar
He's as bad as Can
Have you tried disconnecting / reconnecting the plugs under BOTH seats?
Old Jun 12, 2009 | 03:47 PM
bulletproof21's Avatar
same thing happend to me. It would be on again / off again for several weeks. Took it to Mazda and there was a shorted wire in one of my seats where the side airbags are. Cost $85 bucks.
Old Jun 14, 2009 | 06:47 AM
rx8james89's Avatar
silver rx8
Haven't tried that yet, if not for the sake of £50 could be worth just taking it to mazda and getting it fixed thx for the help everyone.
Old Jun 14, 2009 | 07:29 AM
DeViLbOi's Avatar
The devil made me do it
There is also rumored to be another connection behind the glove box for the pass. airbag that comes loose. Normally just disconnecting and reconnecting both seat connections takes care of it though.
Old Jun 24, 2010 | 10:35 AM
dennisgtofan@msn.com's Avatar
does it mean your airbags don't work when the dash light is on?
Old Jul 11, 2010 | 02:52 PM
saad84's Avatar
i would like to know that answer
Old Aug 11, 2011 | 09:46 AM
phey_05's Avatar
Hi,
Did you manage to take off the airbag on the driver and passenger seat without blowing it? is there an independent sensor inside that airbag? im planning to replace my seat cover, but im a bit worried if i have it replace, the airbag will blow-up.
Or?
it wont be affected since the connectors are not connected and there's no power/sensor connected to it?
if there's any written procedure how to take off those airbags, it will be highly appreciated...
Old Aug 11, 2011 | 05:35 PM
SYKOTIKKUSTOMS's Avatar
mine just came on yesterday????
Old Aug 11, 2011 | 09:07 PM
phey_05's Avatar
Old Aug 12, 2011 | 07:29 AM
air bag light
My air bag light decided to come on out of the blue...so when I start the car it blinks for a few minutes and then stays on
Originally Posted by phey_05
Old Aug 12, 2011 | 10:58 AM
EDZRIDE's Avatar
2005 White GT
Try this: https://www.rx8club.com/showthread.p...=air+bag+light
Old Aug 12, 2011 | 11:37 AM
HiFlite999's Avatar
Hi,
Or?
http://freeservicerepairmanual.com/a...repair-manual/
Generally, it's a bad idea to work on this car with the battery connected, but especially so when it involves the airbag system.
Old Aug 12, 2011 | 12:54 PM
Wingznut's Avatar
Go Red Wings!
Definitely disconnect the battery when working on the airbag system. That being said, while I haven't seen an RX-8 schematic specifically, every other system I've worked on requires two sensors to simultaneously sense a crash to activate the airbags. Otherwise, a single sensor malfunction could cause disastrous events.
Old Oct 31, 2011 | 08:47 PM
jsudz08's Avatar
X08
My light is also on, the code says something about the passenger airbag, the one above the glovebox. I was curious if anyone knew which connector was for the airbag? It's kind of tight under there and I just want to make sure I check out the right one.
cliffkemp
Dec 24, 2024 10:48 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
xAgyex
Sep 28, 2015 08:54 AM
Evan Gray
Sep 26, 2015 12:30 PM
