Hard Start & Sluggish
Old Jun 1, 2009 | 11:41 AM
daddyg's Avatar
Hi there
I have a 04 MT with approx 50K km on it. Same original plugs, coils wires etc.
I did have a flooded engine back in march of 2008 (stalled car reversing right after starting it up) and had the plugs dried out, engine drained etc at dealership. No issues after that.
Lately, it seems that my start is harder than before, it takes a few seconds to start instead of nearly right away.
Also, in 1st at a light/hill etc, if I stomp the gas, it seems to not have the same power it had. Seems sluggish until I hit higher RPMS Once I get going, response/throttle seems the same.
Could this be needing new plugs/coils? Any feedback would be great.
Old Jun 6, 2009 | 11:16 AM
jiggawha1's Avatar
Tejas
Yea try that, if that doesn't help then try cleaning your MAF sensor, and if that doesn't help then you may be in need of a compression test. Do you lose power at high rpms?
Old Jun 6, 2009 | 03:48 PM
invasion08's Avatar
First do the basic maintance stuff like change the ignition coils and spark plugs. If the problem is still there take the car to the dealer. You may be a new cat converter or engine.
Old Nov 18, 2009 | 05:50 PM
g0rdhan's Avatar
forgive my lack of knowledge.. when you check the plugs and coils, what are you looking for specifically?
Old Nov 18, 2009 | 06:17 PM
epikeddie's Avatar
The spark plugs can show signs of fouling (covered in soot and black stuff) or running lean (covered in a chalky white residue). If you have the plugs out, then most likely you'll be replacing them with new ones anyways.
The coils need to be inspected using a multi-meter to check for a few readings. The "burn spots" that many experience on the coils themselves aren't really a good indication to see if the coils are operating within the efficiency range.
poppinparker
Aug 10, 2015 09:20 AM
Tyblat
9
Aug 6, 2015 10:43 AM
harithac
Jul 25, 2015 04:21 PM
dbarber
Jul 25, 2015 01:34 PM
