anyone have a sway bar?
Old May 26, 2009 | 06:18 PM
AndreS123's Avatar
I'm looking for a front sway bar for an RX8... anyone have one local to the Seattle area that they have taken off?
Old May 26, 2009 | 06:20 PM
Spinning Sushi's Avatar
I <3 Sushi
Please be more descriptive.
Are you looking for the base model or sport model sways?
Are you looking for the front or rears?
Do you need the bushings and endlinks that go with it? You will need those too if you're putting it in a Miata.
Please be more specific.
Old May 26, 2009 | 06:35 PM
AndreS123's Avatar
I prefer having the bushings with it, but I don't need the end links, I need to measure it to be sure it fits first....
which model? prefer 24mm or larger diameter... its going on a street/strip car that will have it disconnected at the strip.
If it fits, it'll be going on a LS1 swapped '88 RX7... the stock bar bend hit the oil pan so I took it off.
Old May 27, 2009 | 02:01 PM
RawrX8's Avatar
Grocery Getter
Sounds like you should run a dry sump.
Old Jun 4, 2009 | 01:32 PM
AndreS123's Avatar
not doing a dry sump for the time being, just looking to get some measurements on an RX8 sway bar..... and possibly purchase one.
Old Jun 4, 2009 | 01:56 PM
RawrX8's Avatar
Grocery Getter
In about another week my rear PT sway shows up and ill be swapping them out. If you havent found one by than and can wait ill have one.
RX-8 Racing
20
May 14, 2016 06:25 PM
OfficerFarva
Dec 5, 2015 10:53 AM
duworm
Oct 1, 2015 04:57 PM
Steve Dallas
Sep 19, 2015 09:39 AM
