Clutch/Gear issue
Old May 10, 2009 | 07:25 PM
RoTaRyRx-8's Avatar
RoTorY
Clutch/Gear issue
I just changed my clutch/flywheel and it has almost 400miles on it. It was getting into gears alright but earlier today it started getting hard to get into. When clutch was getting put in my mechanic bleed the clutch and it was alright.This is the second time he bleeded my clutch. Now, for some reason, it doesn't want to get into gear at all. Could it be my slave cylinder?(how much do those retail at auto parts) Theres enough fluid in the brake/clutch system. Also when I press in the clutch, it makes noises when i let the clutch out , like a clicking sound. Any suggestions on this issue would be helpful
thanks in advance
Old May 10, 2009 | 08:27 PM
could be slave cylinder, but it is an early sign of this..
https://www.rx8club.com/showthread.p...76#post3013676
Old May 10, 2009 | 08:31 PM
RoTaRyRx-8's Avatar
RoTorY
so you think that the clutch bracket could be causing it not to go into gears???
Old May 10, 2009 | 08:41 PM
syntheticdarkness's Avatar
ThEy MaDe Me Do It
It was hard to shift on mine, especially when it would get cold, then it snapped. Take it off and get it welded before it brakes. Here is a DIY, should only be about $20 or free if you know someone or can do it yourself.
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-clutch-pedal-bracket-removal-fix-170387/
Take pictures of it just in case ny needs it, or record it when you push it in. Hope this helps you.
Old May 10, 2009 | 08:56 PM
RoTaRyRx-8's Avatar
RoTorY
well right now im not sure if its the clutch bracket or what ???
Old May 11, 2009 | 02:51 AM
Jon316G's Avatar
Grasshopper
If you upgrade the clutch you really should reinforce the clutch pedal (by welding or bracket).
When releasing the clutch pedal, does your engagement point appear a lot closer to the floor?
Old May 11, 2009 | 03:06 AM
it is a likely suspect.
Old May 11, 2009 | 08:04 AM
RoTaRyRx-8's Avatar
RoTorY
i used to have a upgraded act clutch, and the first time it was on the floor, then i had to change my clutch, so i put in a exedy oem clutch after a day it wouldnt let me go in gears, so i thought the mechanic didnt do something good i took it back, and he told me he didnt bleed the clutch right and yesterday it happens again but every time i shift i hear the clutch pedal/bracket squeak and its kind of loose so im prettty sure right now that its the clutch bracket ....
Old May 11, 2009 | 09:45 AM
jsjjr's Avatar
His 8
Does this issue affect all RX8's or just certain years? ( I guess I could read the other thread, but it seems easier just to ask first.)
Old May 11, 2009 | 10:10 AM
yes, and yes.
Old May 11, 2009 | 10:52 AM
ferg's Avatar
yeah my cluch feels really tight after 15min of driving, not to sure why, i remember turning the cluch bolt to make it closer to the floor, but i only moved it a little little bit, it works fine,
Old May 11, 2009 | 09:58 PM
RoTaRyRx-8's Avatar
RoTorY
My mechanic came over today and he found what the problem was, my slave cylinder has a leak so im geting that fixed tomorow and prolly the next might be the clutch bracket
Old Oct 17, 2009 | 04:04 PM
ferg's Avatar
if your cluch is making a squeaking sound, is there anywhere i can put grease to help it stop?
LB2739
Jul 9, 2019 02:25 AM
Irvinb16
Sep 11, 2015 10:27 PM
tgaffner
Sep 7, 2015 08:49 PM
