Pictures: Spark Plugs @ 37.5K Miles
Old May 4, 2009 | 02:19 AM
milesprwr's Avatar
Recently installed a new set of spark plugs. I took pictures of the plugs I pulled with ~37.5K miles on them. For your viewing pleasure:
Old May 4, 2009 | 02:30 AM
636's Avatar
636
Rice Police
wow lmao.
Old May 4, 2009 | 02:36 AM
milesprwr's Avatar
Hehe thanks - here's a link to a recent post and could use some input as well!
https://www.rx8club.com/showthread.p...53#post3002153
rx8sergio's Avatar
thats not good lol
Old May 4, 2009 | 02:38 AM
shaunv74's Avatar
Power!!
That looks normal.
Old May 4, 2009 | 03:20 AM
rx8sergio's Avatar
never mind i guess its normal...i pulled mine at 45k and they were much cleaner than that thou
Old May 4, 2009 | 06:06 AM
souljamcdiddy's Avatar
I pulled mine at about 43k they looked the same, with the exception of one was broken. When I took the wires off, one of the plugs came off with it. No force required it was that brittle.
Old May 4, 2009 | 09:56 AM
maximyuryev's Avatar
I pulled mine out to check on them about a week ago, first time ever doing so, and all of the plugs are round all the way around, like the second picture. is that normal?
Old May 4, 2009 | 10:25 AM
Atilla's Avatar
I am THAT guy
crap...looks like mine are probably gonna be worse...44k currently I've been laggin'....
Old May 4, 2009 | 11:31 AM
shaunv74's Avatar
Power!!
That is not normal. It looks like someone gave you only either the leading or trailing plugs (I forget which). You should get a new pair of whichever one's you're missing and swap them out ASAP.
Old May 4, 2009 | 11:55 AM
DarkBrew's Avatar
Extraordinary Engineering
I posted these pictures in Nov 2007. 48,000 miles Leading plugs had been changed in a previous recall.
https://www.rx8club.com/showpost.php...48&postcount=1
These are pretty normal looking for a rotary.
Old May 4, 2009 | 12:26 PM
Nubo's Avatar
Lubricious
looks like maybe a bit of high-speed glazing. There's a bit of crud on the far side of the center electrode on the leading plug. Can't tell for sure but appears somewhat metallic. I'd probably replace these.
Old May 4, 2009 | 07:51 PM
the thickness is from the car running pig rich.
See the back? that shows you it still is running rich. It came from idlig the car before you changed the plugs.
The light tan reveals that you car is still capable of running correctly or you were just recently running the **** out of it and it hasn't had the chance to turn black yet.
Old May 4, 2009 | 08:41 PM
milesprwr's Avatar
Interesting - is it normal than for the RENESIS to be running rich? Just drawing from the handful of comments here stating that these plugs look normal for the amount of miles on them.
Old May 5, 2009 | 01:44 PM
mazdaverx7's Avatar
RX-Heaven
i dont think the plugs look bad at all. a little buildup but for a rotary, thats normal. remember, the engine uses oil in the combustion chamber for cooling and for lubrication. oil burning can really kill a set of plugs, as can high engine temps. i woud feel comfortable replacing those without hesitation but i say that your engine is running well, perhaps a bit on the rich side..better than being too lean
Jesus Martinez
72
Jul 26, 2023 11:29 PM
05TR1CH
Apr 18, 2023 04:56 AM
GK1707
Dec 2, 2015 10:01 AM
PotatoCannon
Sep 6, 2015 11:48 AM
Psychofox
Aug 20, 2015 04:48 AM
