need help with wiring
Old Apr 14, 2009 | 09:57 AM
jaco's Avatar
Hi , please help. I am a newby to both forums and Canbus wiring. Bought a butchered Mazda RX8. Got everything working except speedo and tacho. Need wiring diagram urgently.
Old Apr 14, 2009 | 10:08 AM
Jon316G's Avatar
Grasshopper
Here are the pages for the whole instrument cluster.
need help with wiring-instrument-cluster-1.jpg need help with wiring-instrument-cluster-2.jpg need help with wiring-instrument-cluster-3.jpg need help with wiring-instrument-cluster-4.jpg
Hope this helps.
Old Apr 14, 2009 | 02:55 PM
jaco's Avatar
Thanks, for the quick reply. Much appreciated
Old Apr 14, 2009 | 03:09 PM
jaco's Avatar
Had to fit third party injection system, original got stolen. Fitted f3ds motor on the original 6 speed box. Central locking and fuel gauge is working, had to put in RX& hydraulic power steering. Any chance of actual wire color coding to get gauges working?
Old Apr 14, 2009 | 07:08 PM
teknics's Avatar
Certified Mazda Tech
do any of the stock gauges work or are you only using the Tach and speedo from stock? the stock gauges are controlled by a microcomputer within the stock cluster. I might be able to get the specs on the signals the microcomputer is looking for.
personally in your situation i'd go aftermarket anyway. There are some nice speed/tach combos out there.
kevin.
Old Apr 14, 2009 | 07:13 PM
The speedo and tach won't work without the stock ECU and the trigger wheel from the RX-8 engine
As well..if the ECU and the Dash unit don't "match" the CAN Bus won't let them talk to each other
What EMS are you using..might just want to use an aftermarket dash unit
Old Apr 15, 2009 | 01:40 AM
jaco's Avatar
Unhappy
I am using a locally based ECU called Gotech (www.gotech.co.za) which I think is basicaly the same as Halltech system. I am driving the engine off a 60 minus 2 crank trigger, with wasted spark.
The system has its own outputs for most gauges except odometer.
Would it be possible to use to drive original revcounter and heatgauge?
I would like to use al the original gauges, but being "old school" these new systems seems rather daunting.
Old Dec 22, 2014 | 02:39 PM
russian2's Avatar
Does anyone have any other wiring diagrams? On these diagrams they show the CANbus wires - bLue/White & Green/Black - but they do not specify which one is CAN High and which one is CAN Low. Does anyone happen to know this maybe?
(I am sorry to revive the old thread but hope these questions are relevant)
Old Dec 22, 2014 | 03:26 PM
Normalexception.net - Documents
Old Dec 22, 2014 | 05:31 PM
russian2's Avatar
Originally Posted by 9krpmrx8
http://www.normalexception.net/docum...%20Cluster.pdf gives me the same two wires in the bottom-left corner and again does not specify which one is which
Old Dec 22, 2014 | 05:40 PM
russian2's Avatar
Actually, OBD-II connector wiring diagram helps! http://www.normalexception.net/docum...0Connector.pdf
OBD-II connector pinout is known, so looks like
bLue/White: CAN high
Green/Black: CAN low
Old Dec 26, 2014 | 11:56 PM
Legot's Avatar
Scrappy
Yeah, you're right with those colors!
Also, tapping the CANbus at the TPMS module (top center of the dash) is very convenient since any dev electronics can be hidden in the glove box or where the OEM nav screen goes, with a very short pair of wires. I have mine there along with some other stuff with an Ethernet plug at the glovebox end.
If you didn't know, we have two buses. One runs at 500kHz, and the other runs at 125kHz. The low speed is used for non critical stuff, and the high speed is for engine management related stuff. Fortunately the high speed is the only one that really matters or has useful info.
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
