View Poll Results: Which wastegate should I choose?
Tial V44
0%
Synapse Synchronic 50mm
100.00%
Tial 38mm that I had laying around
0%
Voters: 3. You may not vote on this poll
Tial V44 or Synapse Synchronic 50mm Wastegate
Old Apr 9, 2009 | 11:36 PM
seikx8's Avatar
Is this title ok?
Question Tial V44 or Synapse Synchronic 50mm Wastegate
So the question is: which one should I choose? I'm leaning toward the Tial V44 but the Synchronic is very tempting with many pluses. I'm planning to run low boost in the range of < 5psi daily but might increase for tracking. Does any one have experience with the Synchronic wastegate on their 8? I have about 1-2 weeks to finalize my plan and it is for my custom homemade low budget front mount turbo.
Or should I just use the 38mm Tial that I had laying around with a lower pressure spring and call it a day?
ps: Anyway to edit the poll end date? I thought I entered 4-20-2009 not 4-13-2009
Old Apr 10, 2009 | 09:57 AM
Jason's Avatar
RX7store.net
We have used both the Synapse 50mm and Tial 44mm on many RX-7 projects. Both are nice wastegates but I prefer the Synapse over the Tial. Either of them will work fine.
Old Apr 13, 2009 | 07:03 PM
seikx8's Avatar
Is this title ok?
Thanks, look like Synapse will be the answer but I won't be buying it anytime soon due to cut back in budget since my welding machine just give up on me. The repair/replacement bill will be in the hundreds, so I have to factor that into my current budget
Old Apr 13, 2009 | 09:47 PM
kersh4w's Avatar
Hit & Run Magnet
arent you a blast from the past?
Old Apr 14, 2009 | 09:19 PM
seikx8's Avatar
Is this title ok?
You can say that again.
I was designing the new engine mount to allow easier exhaust & larger wastegate pipe routing when the welder went out. I guess the project will get a week or two of delay. Hopefully by then, I will have enough $$ saved to get the Synapse 50mm wastegate on top of a new welder like the Miller diversion 165 AC/DC TIG. Hopefully this one will last many years unlike those ebay knock off
I do really like the synapse just couldn't decide by myself and want some reassurance
Thanks guy,
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
9krpmrx8
Nov 5, 2015 11:45 PM
azian6er
General Automotive
33
Nov 30, 2004 04:14 PM
